1. power4rmor's Avatar
    Hi! I have a Galaxy Note 4 that was heating up so I brought it to the Samsung service center and they said that the hardware is ok and they just updated it to 5.1.1. My warranty ended 3 days ago after I got my phone back and now the battery drain is just too much. The last 2 nights I would leave my wifi and sync on and I will get 15% to 20% battery drain unlike before it was around 2% to 5%. I did a partition cache wipe earlier and charged my phone. So far I got 3 screenshots to show. I hope you guys can tell me what is going on. Thanks!
    I live in the Philippines.
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-05-17-33-59.jpg
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-05-17-35-16.jpg
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-05-17-35-53.jpg
    11-05-2015 03:43 AM
  2. Saahiruk's Avatar
    just went into my samsung store battery had the same issue they replaced the battery under the manufacturer warranty
    11-05-2015 07:38 PM
  3. power4rmor's Avatar
    Thanks!
    Here are more screenshots if anybody can help me out with this. Thanks!
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-06-13-26-40.jpg
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-06-13-26-59.jpg
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-06-13-27-14.jpg
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-06-13-27-21.jpg
    Why does my Galaxy Note 4 have a bad battery life?-screenshot_2015-11-06-13-27-42.jpg
    11-07-2015 01:24 AM
  4. cvail's Avatar
    I was recently fighting battery drain on a couple phones and did 2 things to help identify the problem.
    1 - fully charge the phone and set it next to your router overnight (so you know you have a strong connection). If you see abnormal drain overnight. ..
    2 - fully charge the phone, turn on airplane mode, and let sit overnight. Doing this, I verified that my phone is struggling getting a signal at my workplace. If you see abnormal drain overnight. ..
    3 - install the app 'ShutApp'. I found out my wife's phone had 60 apps running in the background - apps she never even uses. Yes, 60.
    Repeat steps 1 and 2 with ShutApp installed. If you still have bad battery, factory reset time.
    11-07-2015 03:16 PM
  5. power4rmor's Avatar
    I already did 4 factory reset and I just find it strange that after getting my phone from the samsung service center this problem shows up. Last night I turned off my wifi and sync and still lost 10% battery. I should just bring it back to them. Can anybody share their note 4 battery screenshot? Thanks!
    11-07-2015 09:14 PM
  6. Rarry's Avatar
    Are you using Sidesync? That might cause battery to drain. That was my experience anyway.
    11-08-2015 02:01 AM
  7. Bosbouer's Avatar
    The OP's Screenshots reflect the worst time remaining that i have ever seen on AC. 5 hrs at 100% estimated! And yet at 50% it is still 5hrs estimated. There is something drastically amiss here.
    11-08-2015 02:41 AM
  8. cvail's Avatar
    If you did a factory reset, you should leave it fresh reset and do the overnight test on airplane mode (so no cell or wifi) services are running. If you have more than 4-5% down after 8 hours of no use from a fresh reset and 100% charge - you have a hardware problem. If you're 95-98% in the morning, you have a cell, software, or app problem.
    11-09-2015 07:49 PM
  9. Dankees's Avatar
    Ugh, my battery is still giving me issues. I did a proper Factory Data Reset. I restarted without using any back-ups (really a fresh start). I only downloaded Google applications and a few things I always use. I just don't get it.
    18 minutes in, and I'm down 8% battery life already. After 18 minutes, I used to only be down like 2%.
    What can I do? This is a nightmare!
    11-11-2015 09:22 AM
  10. Rmedy21's Avatar
    This is always an issue with Android phones. Best thing I can tell you is that. If you aren't a big fan of extended batteries either carry or charger or spare battery.
    Quote The Note 4 Never More😤
    11-11-2015 12:52 PM
  11. power4rmor's Avatar
    Sorry for the late reply. I returned my phone to Samsung and now I wait.
    Nope.
    It makes me cry and it made me buy a Note5. Sigh.
    I guess I will try that when I get my phone back. This is my first samsung battery drain issue and it drives me nuts.
    Bosbouer likes this.
    11-12-2015 12:38 AM
  1. How can I recover my scribble notes on my HTC Desire 816?
    By AC Question in forum HTC Desire 816
    Last Post: 12-06-2015, 12:08 PM
  2. Does clearing the Cache on a mobile cause more data to be used?
    Last Post: 11-06-2015, 02:39 AM
  3. 1500mAh Li-Ion Battery, what is a normal battery life?
    By JReyes23232 in forum Batteries
    Last Post: 11-05-2015, 03:34 AM
  4. My phone doesn't find my SIM after an update to Android 5.0.2?
    Last Post: 11-05-2015, 03:30 AM
  5. Does Act2fit pair bt 4.0 dongle on Windows 7 desktop?
    By kuppi in forum General Help and How To
    Last Post: 11-05-2015, 02:24 AM
