1. Childlike Director's Avatar
    OK,I droped my Samsung galaxy note 4 in water. Immediately i took out the battery and dried it well. Later, I put it back i and i can't see the screen, but all the sound/notifications are working. Anyone know how to fix screen?
    11-07-2015 03:53 PM
  2. Golfdriver97's Avatar
    The whole assembly may need to be replaced. Have you called any local repair shops? Some PC repair places are starting to get into cell phone repair too.
    11-07-2015 04:45 PM
  3. brothamoveson's Avatar
    Could need to dry out some more also.
    Diggin my Note 5 and Note 4.
    11-07-2015 11:30 PM
  4. waydavis's Avatar
    I'm also thinking drying longer.
    Posted via my LG V10, on T-Mobile.
    11-08-2015 01:12 AM
  5. Rarry's Avatar
    You can Google ways to dry it out but I heard rice is good as it will absorb the moisture.
    11-08-2015 01:38 AM
  6. shotboogie's Avatar
    I dropped mines in the toilet about 2 weeks ago what I did was remove the battery and the Sim card then put the whole phone in a big bowl of rice let it dry 14-24 hrs works like a charm now hope this helps !!!!
    toenail_flicker and dabombcra like this.
    11-08-2015 06:36 AM
  7. toenail_flicker's Avatar
    First thing you should have done after pulling the battery was put it in a bag of uncooked rice for a few days. Only way to really dry it out. Even then you'd likely end up the same way. Insurance claim or phone repair or new contract.
    Dustoff-00 likes this.
    11-08-2015 07:07 PM
  1. How do I retrieve photos from my cache data file
    Last Post: 11-07-2015, 07:43 PM
  2. How do I put a S3 as my boost phone
    By nana net in forum Ask a Question
    Last Post: 11-07-2015, 07:41 PM
  3. Replies: 1
    Last Post: 11-07-2015, 07:38 PM
  4. Transferring Data from Note 4
    By wgragg in forum Samsung Galaxy Note 5
    Last Post: 11-07-2015, 04:10 PM
  5. Replies: 0
    Last Post: 11-07-2015, 03:35 PM
