1. kobe008's Avatar
    So my battery doesnt last near as long as it used to. I purchased my Note 4 full price from Best Buy because I have unlimited data and my carrier is Verizon. Who should I contact for warranty replacement on the battery? Verizon, Samsung, or Best Buy?
    11-13-2015 10:35 AM
  2. Spagman72's Avatar
    Before jumping to conclusions that the battery is at fault did you check to see if certain apps are the cause of the poor battery life?
    There are many posts about battery life and different solutions.
    I'm not saying that It can't be the battery.... You just want to try everything first to be sure.
    11-13-2015 10:48 AM
  3. clownin72's Avatar
    Contact Verizon. I did last week and received one under warranty
    11-13-2015 12:15 PM
  4. jayochs's Avatar
    I'm dumb and didn't call into verizon before my warranty was up, which ended October 23rd... so i just went to best buy today and coughed up the 40 bucks for a new battery. I was having issues where it would be at 25 percent, then within a second drop to12,then 1 second later power off and when I plug it in, it's at 0. lol
    11-15-2015 05:08 PM
  5. dyker's Avatar
    Did getting a new battery this fix your battery issue? I have this too. 35% then 30 seconds later 15% and it's asking if I want to conserve. And 30 seconds later 1%. I think some battery cells died.
    Also, this is why I won't get a note 5 or any phone with a sealed battery. One year in and battery issues. Good luck note 5ers... Samsung didn't suddenly drop in a higher quality battery in your devices.
    11-20-2015 02:18 PM
  6. Karlzweb's Avatar
    If you have the insurance through Verizon, it covers batteries. I assume since the note 5 battery is sealed, they will send you a replacement.
    11-22-2015 10:13 AM
  7. TechNut79's Avatar
    I purchased a clearly not OEM battery through Amazon that luckily wasn't too expensive. I'll have to contact Verizon although I believe I'm out of warranty. I do have the protection plan though so we'll see.
    11-22-2015 12:35 PM
  8. dabaum's Avatar
    I had the same issue with the battery charge "disappearing" randomly. I contacted Verizon 1 week before my warranty was up and they just sent me a replacement phone. Problem fixed, it wasn't the battery at all, it was a hardware issue.
    11-22-2015 02:21 PM
  9. TechNut79's Avatar
    If I were to need a replacement phone, it'd be my third Note 4.
    11-22-2015 03:06 PM
  10. KBlack2595's Avatar
    it not a battery its a software problem I have this all the time where I go from 30 to 15 to dead but if I take it out for a few mints and put it back in I still have 30 and it happens a lot when I swap batteries
    11-23-2015 06:58 AM
  1. Android Wear Battery Stats
    By Willber G in forum ASUS ZenWatch
    Last Post: 12-26-2015, 09:15 AM
  2. Battery Pack
    By Delirious D in forum Samsung Galaxy Note 5
    Last Post: 11-18-2015, 11:28 AM
  3. Replies: 3
    Last Post: 11-14-2015, 04:51 PM
  4. HTC One M7: Not working, battery dead?
    Last Post: 11-12-2015, 10:06 PM
  5. Replies: 0
    Last Post: 11-12-2015, 06:59 PM
