1. JimA's Avatar
    Is there any way or any app that will automatically turn Verizon messages off at night? I like to use the pop up feature, but when it comes on at night it lights up my whole room hahaha. I need to be able to receive phone calls at night but that is all I need. Thanks in advance.
    11-14-2015 12:06 PM
  2. Kage87Z's Avatar
    Had the same problem and discovered that putting the phone on it's screen at night solved it.
    11-14-2015 01:36 PM
  3. JimA's Avatar
    Thanks for your quick reply. However, when I am traveling I use my phone as my alarm clock. Face down won't work.
    11-14-2015 01:41 PM
  4. pduffer's Avatar
    Why won't face down work? I use my phone as my alarm clock every day and it is always face down while I'm sleeping.
    11-14-2015 02:54 PM
  5. JimA's Avatar
    Because if it is face down I can not see it as a clock.
    11-14-2015 02:58 PM
  6. pduffer's Avatar
    Do you keep your display on? If not it's about as easy to turn the phone enough to view the time and set it back down as to turn the screen on to view the time.
    11-14-2015 03:53 PM
  7. bryonp's Avatar
    Just go into the settings at night and turn the pop up off simple or turn off the pop up over lockscreen you have those 2 options very simple enjoy!
    dabombcra and Tatt2014 like this.
    11-14-2015 04:17 PM
  1. Do A Reset But Avoiding Verizon Software?
    By jnfields in forum Verizon Galaxy S III
    Last Post: 11-19-2015, 12:23 PM
  2. Replies: 1
    Last Post: 11-17-2015, 02:43 PM
  3. Replies: 0
    Last Post: 11-14-2015, 11:51 AM
  4. How can I fix an error message I am getting when I try to download?
    Last Post: 11-14-2015, 11:47 AM
  5. How do I check age, time and use of of Samsung Galaxy Neo Plus?
    Last Post: 11-14-2015, 11:41 AM
