1. AC Question's Avatar
    Hi all
    I am using Samsung Galaxy note 4 910f and facing NFC problem from last week it was working fine before 2 weeks and I did o share files using it ...
    But now when I turned in on I turns into green indicating "on" in the setting but nothing shows up on the Bar (where battery and other options are visible like signs) and I am unable to transfer anything using it
    Please answer my Query
    I am very worried
    11-20-2015 11:01 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this persist after a reboot? How about after wiping the cache partition? https://support.t-mobile.com/docs/DOC-14686
    11-20-2015 11:25 AM
  1. Tmobile Note 4 $300 - Microsoft Band 1 $70 (small)
    By achiquitachaser in forum Marketplace Archive
    Last Post: 02-17-2016, 12:16 AM
  2. Where did my sticky notes go?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-20-2015, 03:23 PM
  3. record announcement on Galaxy note 4
    Last Post: 11-20-2015, 11:52 AM
  4. Replies: 0
    Last Post: 11-20-2015, 09:37 AM
