1. melmc1403's Avatar
    Hey!
    Before the 5.1.1 update I was able to go into my battery settings and see how many hours my phone had been running since its last charge. Now it only tells you how long you have left on your battery. Can anyone help?
    Thanks
    11-20-2015 03:21 PM
  2. SpookDroid's Avatar
    That's odd, for me it's still there in a Note 5. Is your phone carrier branded? If so, it might have been something that the carrier eliminated. For me it shows up below the usage graph as time since last fully charged.
    You can use 3rd party battery monitors, of course, but not sure why it's not in the system report.
    melmc1403 likes this.
    11-20-2015 03:33 PM
  3. melmc1403's Avatar
    No I have an unlocked note 4 here in Northern Ireland.
    11-21-2015 05:53 AM
  4. Tsepz_GP's Avatar
    Hey!
    Thanks
    Its like that on all 5.1.1 Note 4s, its the one thing I hate, I don't get why they took it away.
    11-21-2015 03:43 PM
  5. melmc1403's Avatar
    Why would they take it away......ANNOYING not having it!!
    11-21-2015 03:47 PM
  6. TechNut79's Avatar
    That's weird. For me it just shows the graph that you have to try and figure out how long it's been off the charger. I think it's always been like that.
    11-21-2015 03:53 PM
  7. Tsepz_GP's Avatar
    Agreed!
    These are the pains of owning a Samsung, sometimes they just do stupid things.
    11-21-2015 03:53 PM
  1. Battery Life
    By dbregman in forum TAG Heuer Connected
    Last Post: 10-25-2016, 04:12 PM
  2. Check battery cover?
    By Rikku Watro in forum Ask a Question
    Last Post: 01-27-2016, 06:16 AM
  3. Battery Drain Issues & Resolutions
    By Masheen in forum Motorola Droid Turbo 2
    Last Post: 12-01-2015, 11:09 PM
  4. Replies: 3
    Last Post: 11-22-2015, 10:07 AM
