1. AC Question's Avatar
    I want to ask.. something that i dont know everybody have observed or not .. see when ever i take photos of a light or bright image .. it some kind distort i mean to say some spikes of that light comes alongside (like when we were kids we used to draw the picture of a sun ☀ we put some spikes alongside the circle).. the camera is built out of the surface so i am really concerned about scratches and what for the shots after few scratches .. and whether it will catch some scratches after day to day pocket use..
    11-28-2015 01:24 AM
  2. belodion's Avatar
    Welcome.
    The flare spikes that you refer to sound normal, though will probably be worse if the lens glass is dirty. If yours seem abnormally bad, attach a screenshot so that we can judge.
    Yes, the lens glass can be damaged if unprotected. A case, and/or a lens glass protector, will afford extra protection.
    786chatur likes this.
    11-28-2015 09:53 AM
  3. 786chatur's Avatar
    Please take a view.. and tell whether this is normal.. and also is it protected by some coating would day to day pocket use(sliding inside outside pocket) affect the camera lens sometime i even accidentally touch the lens..
    Attached Thumbnails Note 4 camera help for scratches and smudges?-20151008_190459.jpg
    11-28-2015 02:12 PM
  4. belodion's Avatar
    Welcome as a new member.
    No, that is not normal. I understood your original thread to mean streaks emanating in all directions. The ones in your photo look like the effect you would get from a greasy fingerprint, say, smeared across the lens glass in one direction, or from scuffs or abrasions on the lens glass in one direction.
    What does the lens glass look like if you examine it closely? If damaged, it may be possible to replace only the glass.
    There may be some other cause, but I don't know what it would be.
    I'll refer your question to one or two Note 4 owners.
    11-28-2015 03:54 PM
  5. 786chatur's Avatar
    Very very thank you.. the is glass is good.. just minor scratches but i am probably sure that those minor scratches on lens wont do the problem .. am i right ? Last question to you genius :P .. as you know the camera is little out of the phone and when keeping on the table camera get touched touched to the surface so i want to ask that is it any going to make camera bad.. i am also protecting it with a layer of plastic with the hole at the center likewise the plastic came covering the lens when i brought it new..
    11-28-2015 04:38 PM
  6. belodion's Avatar
    I'm not very familiar with the Note 4, but if you're saying that you have a plastic protector covering the lens glass itself, remove it. If it's just surrounding the lens glass, with a circular cutout for the lens to look through, that will not protect the glass itself.
    A protruding camera is always a problem, but a case will often give protection by, in effect, raising the level of the back to that of the module.
    Laura Knotek and 786chatur like this.
    11-28-2015 04:56 PM
  7. 786chatur's Avatar
    Does the camera lens made of some scratch protective glass or coating.. will do as you have said.. thanks you for all your help and yes you really solved my every problem.. take care
    11-28-2015 05:29 PM
  1. Replies: 26
    Last Post: 12-01-2015, 12:36 PM
  2. Help battery life draining super fast
    Last Post: 11-28-2015, 09:54 AM
  3. locked out of my phone please help
    By optimus prime konjo in forum Samsung Galaxy S5
    Last Post: 11-28-2015, 06:22 AM
  4. How to change ART and Dalvik runtime?
    By Shahbaz Talpur in forum Samsung Galaxy Note 4
    Last Post: 11-28-2015, 03:52 AM
  5. Emoji in text box won't access Emojis anymore on my Samsung Note 4, why?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 11-28-2015, 12:11 AM
