daiwolf
Thats awesome...all Verizon Note 4 users are still on 5.0.1
I'm on vzw downloading 5.1.1 now it's out
Where are you located?I'm on vzw downloading 5.1.1 now it's out
edit: I just checked and I am downloading the update now! Location: SoCal
Finallllllly!!!
I always do a factory reset after any firmware update and always happy I did.What is the general consensus about whether you should clear your cache after installing an update? Is it recommended?
I feel if you're jumping from 5.0.1 then a factory reset wouldn't be really needed unless you end up with some major headaches. If you're jumping from Kit Kat then I would highly recommend a FDR. I had a few issues when jumping into lollipop and an FDR solved most issues for me.I always do a factory reset after any firmware update and always happy I did.
