kirksucks
Just updated. Opened camera (storage set to card) took a pic hit preview.. Lag was like 8 seconds.
Does the class of the memory card affect the lag you think?Just updated. Opened camera (storage set to card) took a pic hit preview.. Lag was like 8 seconds.
What class is your card?I never changed my card.
Just checked again... 6-8 seconds on card. 3-4 on phone memory. Friend's s6 is instantaneous. I had to do a double-take to see what camera app they were using.
Is there a way to check without taking it out?What class is your card?
No way of speeding up the transition to gallery on the stock camera. This has been noted on several forum. I think it won't get fixed. However I use snap camera. Such a better camera and viewing picture is a snap. Should check it out as an alternative.Is there a way to check without taking it out?
Well the crappy 5.0.1 update has me seriously considering buying another note 4 unlocked from att and moving my service to cricket. Surprisingly better coverage when I'm at especially now with this update and lack of cell coverage from the phone not pulling in the signal
Funny thing is I already did this last month and so far so good. Cricket is excellent where I'm At and half the cost. I was a Verizon customer for 7 plus yearsThis is smart. Run the numbers. I bet it saves you a lot of money. Cricket is really good. We are all creatures of habit. But you Verizon users sure are like the abuse.
Look at this thread:Odd, Got the update, went to the advanced settings under Wi-Fi and saw "Automatically connect to AT&T Wi-Fi Hotspot when detected". I have a Verizon Note 4.
Reset your camera settings, and you will see the difference.I never changed my card.
