N
Niko
Hi, I really hope someone to have a solution on this.
When I draw a line, for example and then try to erase a bit of it, it erases a short line may be about a 4 mm of a line and doesn't feel like an eraser. Setting on it is on setting 1.
On note 2 it feels more like a real eraser it just smoothly erases. And not as note 4 lag of a 4 mm line per second.
I tried resetting phone too and uninstalling all of the apps but still the same.
Do you have the same issue? Can it be fixed to a smoother eraser expirience like note 2?
