1. Rmbrown1964's Avatar
    I did a reset yesterday to start fresh. Not sure what happened but now I have a wifi problem, it keeps connecting and disconnecting from my xfinity wifi router. My phone is a Note 4 on AT&T. All other cell phones and tablets and laptops work fine. Never had this problem before. Any help would be appreciated thanks
    12-18-2015 10:13 PM
  2. B. Diddy's Avatar
    Try rebooting the router by unplugging its power for 10 seconds, then plugging back in. See this guide for more ideas: http://forums.androidcentral.com/amb...-problems.html
    12-18-2015 10:30 PM
  3. Rmbrown1964's Avatar
    I did that to and no luck. Also rebooted my phone. I will read the link you sent me. Thanks so much for your help.
    B. Diddy likes this.
    12-18-2015 10:40 PM
  4. B. Diddy's Avatar
    If you have Bluetooth on, turn it off and see if that makes a difference.
    12-19-2015 12:05 AM
  5. Rmbrown1964's Avatar
    In the WiFi setting there is a check box that allows a smooth switch over between 5 and 2.5 I unchecked it and now it's fine.
    12-19-2015 11:29 AM
  1. Firmware or reboot problem? Need help in fixing
    By VVendetta in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 12-31-2015, 08:35 PM
  2. PLEASE HELP! "Low memory" and "Storage space running out"
    By czyxx71 in forum General Help and How To
    Last Post: 12-23-2015, 05:34 PM
  3. Replies: 1
    Last Post: 12-19-2015, 09:06 AM
  4. Samsung S4 Battery Discharge Rate on WIFI
    Last Post: 12-18-2015, 10:46 PM
  5. Connecting to wifi
    Last Post: 12-18-2015, 06:35 PM
