1. piannetta's Avatar
    Hi there, so e all know that Samsung stuffed things up with the notification LED as part of the 5.1.1 upgrade. And we also know that existing 3rd party apps also don't work. So is there any way at all that anyone has come across to customise the LED behaviour on the Note 4 under 5.1.1 or are we stuck with what Samsung have prescribed?
    Pete
    12-21-2015 03:24 PM
  2. Carrie Greicar's Avatar
    I use light flow and it works great with my note 4. I am on the 5.1.1 os
    12-21-2015 07:58 PM
  3. piannetta's Avatar
    Thanks. I've tried light flow but the notifications side effects are just too annoying. Ultimately Samsung needs to fix what they've done
    12-22-2015 03:21 PM
  4. Dustoff-00's Avatar
    Depending on the app, you may be able to change the color of the notification in the app.....
    open app, touch the 3 dots (upper right side), go into settings, notifications, then look for blinking light color.
    If it will trigger the notification light, it will have a way to adjust it.
    12-22-2015 05:41 PM
  1. Replies: 4
    Last Post: 08-20-2016, 10:36 PM
  2. Note Edge to reading SDcard
    By AC Question in forum Samsung Galaxy Note Edge
    Last Post: 12-21-2015, 04:37 PM
  3. Replies: 1
    Last Post: 12-21-2015, 03:24 PM
  4. Replies: 2
  5. Why is the calendar on my Android Razr Maxx not changing date?
    By AC Question in forum Droid RAZR MAXX
    Last Post: 12-21-2015, 02:51 PM
