1. Liquidretro's Avatar
    Went to update an app in the Play store and it said my phone was out of space. This was weird, I have an SD card in, and its a 32gb phone. I have apps installed but not a ton of them. Upon further investigation I have a 20gb Cache partition. I rebooted the phone and did the clear cache and that didn't make a different.
    If I clear the cache on the storage screen will it clear it from all my apps? So will I have to login again everywhere, etc? Any idea which app is causing this? 20gb is crazy, I reset my phone 8 months ago or so.
    12-23-2015 10:31 AM
  2. ChetManley762's Avatar
    Just go into storage from settings click on the cache and select clear cache. It will clear it out of pretty much all the apps.
    12-23-2015 10:51 AM
  3. Javier P's Avatar
    Yes, it will delete the cache for all your apps.
    No, it won't delete any personal information
    It's difficult to know which app is caching so much data. You could go one by one in your settings - apps until you find it. The usual suspects are browsers, gallery and in general any app heavy on media files.
    You can take a look at this guide about cache.
    http://forums.androidcentral.com/sho...d.php?t=558872
    [GUIDE] A bit of cache clearing
    12-23-2015 11:31 AM
  4. sinfoman's Avatar
    Got Facebook? It's a NASTY NASTY HOG of a program.
    12-28-2015 04:07 PM
  5. goin_nil's Avatar
    Get this app. It's fantastic for helping you to quickly find what is consuming so much space.
    https://play.google.com/store/apps/d...roid.diskusage
    Also, clear cache does not necessarily clear ALL of the cache. For example, with the DiskUsage app I found that the Android Central app had a 600 MB cache! You have to delete the cache from within this app. It's the only way.
    12-28-2015 08:51 PM
  1. Heart Rate Data from Garmin Connect to Google Fit
    By albie999 in forum Health and Fitness
    Last Post: 03-15-2016, 02:22 AM
  2. GPS Problem on T-Mobile Note 4
    By PainFX in forum Samsung Galaxy Note 4
    Last Post: 01-27-2016, 05:05 PM
  3. Replies: 2
    Last Post: 12-23-2015, 09:12 AM
  4. Replies: 1
    Last Post: 12-23-2015, 05:08 AM
  5. Can someon help? Dead screen problem..
    By Klaudio1 in forum LG G2
    Last Post: 12-22-2015, 05:30 PM
