1. Brandwin's Avatar
    I am thinking about selling my Note 4. It doesn't technically have water damage, but it was dropped in water.
    About 8 months ago I dropped my phone in the sink, pulled it right out, turned it off, took out the battery etc... Took it to a phone repair shop the next day. He let it dry and told me everything worked fine. Eight months later, I haven't had one problem with the Note 4. Only issue is, the white strip is now pink.
    So is there any place that will buy the phone or do trade in credit? It looks like it has water damage from the strip, but it's perfectly fine.
    Thanks!
    12-23-2015 05:50 PM
  2. res6jya6's Avatar
    Just... No.
    You're going to have a hard time unloading that phone on ANYONE period.
    12-23-2015 06:12 PM
  3. bable's Avatar
    I've never seen a craigslister check the moisture tag. I think you'd do well and be morally clear if you post it for 25-50$ under average with a disclaimer about the pink but the explanation that it has worked fine.
    12-23-2015 11:49 PM
  4. Brandwin's Avatar
    I may give it a go. I'll make sure I enjoy the Nexus 6P before I unload it. I might just end up keeping it.
    12-24-2015 11:18 AM
  5. goin_nil's Avatar
    Keep it and get a Gear VR to use with it. It's awesome.
    12-25-2015 06:48 PM
  1. My note 4 is completely in loop, what should I do??
    By 4384587 in forum Samsung Galaxy Note 4
    Last Post: 12-30-2015, 03:32 PM
  2. S Pen button design Note 5 is horrible!
    By tankgurl in forum Samsung Galaxy Note 5
    Last Post: 12-24-2015, 10:56 AM
  3. My note 4 is completely in loop, what should I do??
    Last Post: 12-24-2015, 09:34 AM
  4. Find my mobile not working since lollipop install on Note 3.
    Last Post: 12-23-2015, 04:55 PM
  5. My note 4 is completely in loop, what should I do??
    By 4384587 in forum Ask a Question
    Last Post: 12-23-2015, 02:52 PM
