1. MrSaturdaynite's Avatar
    After days of back and forth with at&t I was finally able to get numbersync to work correctly. Apparently there was an update released through the gear app that addressed the numbersync connectivity issues. Welp as soon as I got that fixed , I began having a serious battery drain issue on my note 4. Am I the only one experiencing this? Is there a known solution other than tossing all the equipment in my fireplace!?!!?
    12-26-2015 06:14 AM
  2. sinfoman's Avatar
    Tried the good ole' cache clearing?
    12-28-2015 02:44 PM
  3. MrSaturdaynite's Avatar
    I actually cleared the cache and everything seems to be back to normal. THANKS!
    12-31-2015 11:20 AM
  1. My battery suddenly completely died overnight
    Last Post: 12-31-2015, 03:30 AM
  2. Replies: 1
    Last Post: 12-26-2015, 03:02 PM
  3. Replies: 1
    Last Post: 12-26-2015, 04:18 AM
  4. is samsung gear s2 compatible with wiko rainbow
    Last Post: 12-26-2015, 03:09 AM
