1. aximtreo's Avatar
    Hi, just bought a Note 4 for Verizon and activated it today. Everything seems to work OK but one. All incoming calls go straight to Voice Mail; phone never rings.
    Anyone else seen this in the past. Hopefully it just a setting.
    Thanks for any all all help or suggestions.
    12-26-2015 06:14 PM
  2. Miller6386's Avatar
    Were you a Verizon customer before? Sounds like the phone or simply card isn't set up with or registered on the network. Do outgoing calls all show the right number? Did you maybe accidentally turn on do not disturb?
    12-26-2015 06:18 PM
  3. aximtreo's Avatar
    I was a Verizon customer about 2 months ago; took a short sojourn to AT&T and came back today. Outgoing calls go out fine. I'll check the do not disturb setting. Thanks.
    12-26-2015 06:23 PM
  4. Miller6386's Avatar
    Perhaps porting the number back is just taking a little longer than normal. Probably a lot of activations and mess on the network the day after Christmas
    12-26-2015 06:26 PM
  5. aximtreo's Avatar
    Do not disturb is off so it shouldn't be stopping invoming calls. Thanks for the suggestion.
    12-26-2015 06:27 PM
  6. aximtreo's Avatar
    Found the problem. Turns out my number got lost in the porting operation between AT&T and Verizon. Problem solved.
    sinfoman likes this.
    12-28-2015 02:32 PM
  1. Connected to 3G instead of 4G
    By Trophlin in forum Google Nexus 6
    Last Post: 01-04-2016, 04:14 AM
  2. Replies: 17
    Last Post: 12-28-2015, 03:53 PM
  3. Replies: 1
    Last Post: 12-26-2015, 07:53 PM
  4. Replies: 0
    Last Post: 12-26-2015, 06:03 PM
  5. Can you record automatically incoming call w/ video???
    Last Post: 12-26-2015, 05:17 PM
