1. transamgrrl's Avatar
    Had this problem with my S5, now with my Note 4. I used Smart Switch to transfer my stuff over, apparently I transferred the problem too. My husband is using the S5 now, and the battery lasts him over 24 hours. I'm lucky to get 10, out of either phone. I've read every thread I can find about this, tried all fixes, and battery monitor apps. Nothing pops as being the culprit. Android system, OS uses the most resources. I have all features turned off like motion and gestures. Deleted apps like FB, messenger, Amazon. WiFi, GPS, Bluetooth always off. Limited to 1 background process. I've gone into everything like Google Apps and turned off everything that syncs, and location services. Killed every service and process I can. I only surf the web and read e-books. My husband is using YouTube and FB all day, yet his battery lasts twice as long at least, on the same phone. I basically can't use any of the features I got this phone for, or my favorite apps, and still have to charge twice a day. What am I missing here?
    12-29-2015 06:34 PM
  2. Zachary Boddy's Avatar
    It could be as simple as a bug with restoring using Smart Switch. Would you consider factory resetting your phone and starting from scratch?
    12-29-2015 06:48 PM
  3. Cavboygt's Avatar
    Factory reset, download one app monitor your app one at a time or best buy samsung center or Samsung repair center in texas tel# 18553355922 good luck. My battery last 5am to 12am you tube, call, text, games, fb, tw and insta.
    12-29-2015 07:05 PM
  4. muzzy996's Avatar
    Sounds to me like one or more of your favorite applications is to blame. Factory reset and install only a few applications at a time allowing the device to settle in a few hours between each batch until you find out which. I would refrain from doing restoration of data until I found the source of the issue.
    12-29-2015 09:29 PM
  5. ColbyJvonBrown's Avatar
    Could it possibly be a bad sd card? Sometimes if the sd card is full or corrupt, the Android System will continually try to scan and read everything from it, resulting in high usage and therefor killing your battery quickly.
    12-30-2015 01:28 AM
  6. transamgrrl's Avatar
    I did format my SD card, indexing service popped up as using quite a bit of resources. Did another reset. All my app data was backed up to Google and Samsung, so all my apps got reinstalled even though I only selected a couple. Battery drain for 5 hours idle was 15%, another 7% over the last hour just checking email. Better than it was, but still not great. Is there a way to get Google and Samsung to not reinstall everything besides not signing in?
    12-30-2015 10:07 AM
  7. muzzy996's Avatar
    Yes, when you factory reset and are running through the initial setup answer no to automatic backup. Also, if indexing service never settles down something is wrong with the card, either a bad card or corrupt file. I'd reset again, run through setup without backup and phone sit for a few hours with the card in to index, if indexing settles down proceed to install applications in small batches.
    12-30-2015 10:17 AM
  8. transamgrrl's Avatar
    Ok, I thought I did select no to everything, especially to restoring any previous backup files. Must have missed something, I should have realized something went wrong there when it asked what apps to reinstall from the list of the apps I'd had before.
    I'll definitely be keeping an eye on that SD card. Wouldn't be the first card I've had go bad and cause problems.
    12-30-2015 11:22 AM
  9. transamgrrl's Avatar
    Turns out the battery was getting weak. A new battery is giving me 22-24 hours. Swap in the old battery, and it only lasts 8-10 hours.
    muzzy996 and huntnyc like this.
    01-01-2016 02:53 PM
  1. Replies: 1
    Last Post: 12-29-2015, 06:28 PM
  2. Can I get some help encrypting my Galaxy Tab?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 12-29-2015, 06:22 PM
  3. Picture folder help
    Last Post: 12-29-2015, 06:13 PM
  4. Chrome video download question, can I get some help?
    By Fermenter in forum Samsung Galaxy S6
    Last Post: 12-29-2015, 04:57 PM
  5. Replies: 0
    Last Post: 12-29-2015, 04:46 PM
