1. Clocks's Avatar
    Wife showed me her note 4 today complaining "it's been stuck sideways for a few weeks".
    All of her pictures are turned and the icons on the lock screen are always turned 90 degrees.
    I tried toggling the rotation, cleared cache in the bootloader, and tried using an accelerometer calibration app (but it wouldn't work at all).
    Any suggestions other than a FDR?
    01-08-2016 06:40 PM
  2. RockAndRollAcdc's Avatar
    I'd call support first. FDR isn't has bad as it use to be
    01-08-2016 07:38 PM
  3. fatyank's Avatar
    I've had that happen to mine several times. I've done a restart (press and hold off button until pop up appears, press restart) same as pulling battery. Cleared my problem.
    rjr1209 likes this.
    01-08-2016 10:45 PM
  4. rjr1209's Avatar
    I second that
    01-09-2016 03:05 AM
  5. Clocks's Avatar
    Resetting (and battery pulling) didn't help.
    01-09-2016 05:00 AM
  6. Clocks's Avatar
    Dropping it didn't help either
    01-09-2016 10:53 AM
  7. fragologist's Avatar
    My wife had the same issue with her note 4 over a year ago. This is going to sound like I'm trolling you but I fix it by slapping the back of the phone a few times. I held it up vertical with one hand and slapped it on the back with the other. Apparently the accelerometer gets stuck on some of these phones. My wife hasn't had a problem since. I hope this helps.
    I am in the process of making my Note 4 self aware.
    01-09-2016 11:52 AM
  1. HTC M8 stuck in root screen after installing wrong rom
    By AC Question in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 01-08-2016, 05:29 PM
  2. HTC M8 stuck in root screen after installing wrong rom
  3. Tablet hangs up reload pages slow or not at all
    Last Post: 01-08-2016, 05:12 PM
  4. Small bead stuck in earphone jack
    Last Post: 01-08-2016, 11:40 AM
  5. How do I log into wifi guest network at work?
    Last Post: 01-08-2016, 10:03 AM
