Yes, since they are pushed out by the carrier your phone will need to be activated to receive the update. Otherwise we could all have updated 6 months ago when samsung first provided the 5.1.1 update instead of waiting on Verizon.Had the same issue, apparently the phone needs to be activated because as soon I inserted an active sim card into Note 4 the update process started.
You'll need either an active Verizon Wireless sim or maybe try using Kies.Since I have my note 4 Verizon on straight talk, will I receive the update? System says my phone is up to date when I check for an update. Anyone have experience with this?
My update didn't appear on its own - I manually checked for updates and then it appeared.
For me, this update made my phone feel brand new. The multi tasking button that would take a few seconds for it to pop up after pressing it is gone. It's almost instant.So let me ask you guys since its been a few days and some people have got to play with it and beat it up....
Are most of the Bigger problems resolved with this update... (Battery life, lag times, Bluetooth...etc)...? and more importantly, are you seeing any new problems that might be related to 5.1.1 ... other than the Wifi Connection Notice at the top...?
I ask because... I have a Note 4 as well and when I upgraded to 5.0.1 I experienced the same problems as most of you are having. Since I use the phone for business and personal, I had to downgrade to 4.4.4 and blocked all updates shortly after which I'm happy that I did.... Anyway, this week I purchased another Note 4 that I"m going to use as a Backup & Test phone with the intention of Installing the latest 5.1.1 and reinstalling my business apps and see how that functions for a while. My is... if its still problematic I can always move the SIM card back over and away I go without any loss or downtime...
But anyway, I just wanted to hear what everyones thoughts are of the update so far....?
Thanks, Rick..
For those that have updated, is the multi second lag when switching from camera to the Gallery app gone?
The lag has been reduced. Actually the lag throughout the phone had been reduced. The update was much needed.
Curious if you did a complete factory restore prior to updating. I did not notice the recent file button lag so of course I just had to try it. Behold there's a small lag. :-\ I have so much garbage on my locked note4 I just assumed that's why slow and now battery drain too.I updated since release day and so far I've had nothing but a good experience.
This is the good compared to 5.0.1
- Lag is about 90% gone
- Recent button works super fast
- Battery life is about the same or better. I am a heavy user and I normally unplug around 7AM and used to need to charge by 2PM at ~30%. Now it can last until about 3-4pm before it hits 30% and I start charging.
- Battery hasn't gotten too hot since update. GSAM reported as much as 100 degrees when it got hot. Now it has not passed 90 IIRC.
- Overall entire phone feels much quicker.
I want to do an FDR because I read somewhere that someone was getting low 1GB ram usage which is surprising to me. After the update I was getting ~1.9GB of ram used up when I restarted even after i wiped the cache and cached data. I don't have the time to set up everything again but I might do it if I ever get the free time to do it. I hate the hassle of having to set up everything again.
When I upgraded from 4.4.4 to 5.0.1 the phone was so slow that I had to do an FDR. Before upgrading to 5.1.1 I did not do an FDR. I have had the phone running over 160 hours and its still running like a champ. Usually I would have had to restart the phone after a few days.Curious if you did a complete factory restore prior to updating. I did not notice the recent file button lag so of course I just had to try it. Behold there's a small lag. :-\ I have so much garbage on my locked note4 I just assumed that's why slow and now battery drain too.
I 'm on 4.4.4 blocked the updates so I can still root using king and supersume.
In case anyone is still having trouble with the wifi notification, you can remove it. If you're seeing a notification similar to this:
Connected to "****" (Secure)Tap to configure Wi-FiAnd you want to get rid of this, simply tap on that notifcation,
Tap the menu button (the 3 dots at the top right of the screen),
Tap Advanced,
Un-check the top option for "Wi-Fi notifications"
