1. AC Question's Avatar
    i login and then it says log in needed but it wont open the page so i can log in
    01-11-2016 11:57 AM
  2. Kelly Kearns's Avatar
    Welcome to the forums! Usually with something like that I will just manually open a chrome window and it will show up. Once it didn't for me and I opened the stock browser and the login page showed up.
    01-11-2016 12:02 PM
  3. mikeng714's Avatar
    Usually the ssid is either hidden or the school has put in protocol that require you to verify setting before you can open those authentication websites. Check with your schools IT. They should be able to assist.
    01-14-2016 12:17 AM
  4. Revyaanshu's Avatar
    This happens even with your home wifi or mobile data?
    If so, it's a homepage issue.
    01-15-2016 09:37 PM
  5. amirmohammad jahanbakhsh's Avatar
    Air View
    02-01-2016 08:18 AM
  1. WiFi Constantly Disconnecting
    By Dylan Gorski in forum LG V10
    Last Post: 10-25-2016, 10:09 AM
  2. [CLOSED] Contest: Win an Honor 5X from Android Central!
    By James Falconer in forum Honor 5X
    Last Post: 06-22-2016, 06:13 PM
  3. Why is sound only playing from the left earphone?
    By Decoy Dreams in forum Moto G
    Last Post: 01-11-2016, 02:20 PM
  4. [Closed] Win an Honor 5X from Android Central!
    By James Falconer in forum Android Central Contests
    Last Post: 01-11-2016, 11:32 AM
