1. dusanc's Avatar
    Hello,
    Why my stock battery life drop fast only under idle state? It was a 1 yr old Note 4 from my cousin and the issue doesn't happen with the mpj 6440mah extended battery which I bought recently. Anyone out there ever had this problem?
    Thanks!
    01-18-2016 09:02 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If the drain only happens with the stock battery, then the battery is probably wearing down. If the phone was used very heavily over the past year, with frequent deep discharges (i.e., draining it to zero or near-zero), that shortens the overall battery lifespan.
    01-19-2016 01:09 PM
  3. asianguy80's Avatar
    I would recommend getting a new battery. I had the same thing happen to my N4 right around the 1 year mark and once I replaced it with an OEM battery it was like new.
    01-19-2016 02:03 PM
  1. Marshmallow Update Wifi Drain Fix Here
    By hisense in forum Moto G
    Last Post: 02-17-2016, 12:15 PM
  2. New Z5 Premium loosing power fast!
    By barry1964 in forum Sony Xperia Z5 Premium
    Last Post: 01-29-2016, 07:47 PM
  3. How is battery life on the Huawei P8?
    By podrae in forum Huawei P8
    Last Post: 01-19-2016, 07:01 PM
  4. Replies: 1
    Last Post: 01-19-2016, 01:24 PM
  5. Replies: 1
    Last Post: 01-18-2016, 09:19 PM
