Anyone use Android Pay with their Note 4?
tekmantoo
Active member
Dec 18, 2010
25
I added my debit card successfully to Android Pay on my Note 4 and enabled a screen lock pattern. Went to a store that accepts android pay, unlocked the phone with the pattern, and nothing happened. Tried again, still nothing. I have NFC enabled. Am I suppose to use the fingerprint unlock instead of the pattern unlock or do I use both? Thanks for any help.
min_is_3
192
7
My understanding is that Android Pay requires hardware features not found in the Note 4.
Not true. I've used Android Pay many times with my Note 4.
For me, since i use smart lock with my Moto 360 with a 4 digit unlock code as backup when my Moto 360 isn't connected, i swipe to unlock my phone, tap my phone onto the terminal, then i type in my 4 digit phone unlock code, tap the terminal again then a check mark appears.
Aside from having to tap the terminal twice, it's a pretty easy process.
IAmSixNine
3,157
72
Sometimes it can be tricky to line up the NFC antenna on the Note 4 with the antenna on the swipe machine.
I have used my note 4 to pay for food at Jimmy Johns and the first time or two i had to find the correct placement for my phone to work with their system. ALSO the cashier had to ask me what form of payment, i said phone, they were lost, i said credit card, that got the machine ready for my phone to pay. So its possible their POS might require them to select CC for it to work.
kobe008
140
I use Android Pay on my Note 4. I unlock the screen with a pattern and hold it to the credit card machine and in a few seconds it pays.
IndyRoadie
11
I just tried this for the first time last night. I use Pattern Lock as well. First "tap" didn't work. The Cashier told me to hold the phone horizontally and tap it. Ding! Worked like a charm
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
It's never worked for me. I look like an ***** going into the stores tapping my phone :(
Always end up using my card anyway
fatyank
352
Works great on my Note4. I have the alert set to notify me if there is a store in the area that accepts Android pay. The first few times using it are awkward but after that no problem.
KnightRiderRalph
Since I've gotten the Marshmallow Update on my Note 4 I have to do these exact steps every time I make a transaction and its annoying. Before the update all I had to do was unlock my phone and then tap and boom, done. Now I'm forced to enter the backup password every time and its annoying because it slows the process down. Any way to fix this?
nacron
10
Thought it was my dying note 4 that was causing this but my replacement is also asking for backup password. Hope they fix this soon.
sinfoman
101
+1. Worked like a charm before MM. Dear Android, Samsung and (in my case) Sprint, PLEASE fix this. I get that this is a first world problem, but the whole point of securing the device is so we don't HAVE to unlock Android pay a second time! Come on guys....
Posted via the Android Central App on my marshmallowy Note 4
MarcosVo
