01-03-2019 01:47 AM
279 ... 89101112
tools
  1. dpw09's Avatar
    So, 2 days ago, a new lock screen "on top of" my regular lock screen "magically appeared" on my Note 4.
    It shows time/date in upper left corner, and a ... menu in the upper right that allows me to turn off speed charging. Then, a % charged indicator, and underneath that, some annoying ad... at the bottom, there is a "slide to unlock", which then goes to my Nova Launcher lock screen, which I have setup with my fingerprint scanner.
    So basically, now I have to go through an additional lock screen and view an annoying ad to get into my phone.
    I have no idea where this came from, and to the best of my recollection, I haven't added any new apps.
    Any idea how to get rid of this?
    Thanks for your help!
    Here is a good article on how to track the app putting the ads there.
    Android ads on your lockscreen and how to destroy them - SlashGear
    juliesdroidsync likes this.
    09-29-2016 08:02 PM
  2. Qaid_Ali's Avatar
    I think when Peel Smart Remote updated that's when I noticed that Speed Charge Screen. I removed Speed Test to be safe as well. That updated too on my M9 😬 I'll keep everyone posted
    09-29-2016 11:46 PM
  3. Damo1111's Avatar
    After using go keyboard ( the paid version ) for a long while - i deleted it from my phone - GO are the culprits.
    Ads gone
    10-02-2016 05:34 AM
  4. juliesdroidsync's Avatar
    As the OP, I'm really surprised at how often this seems to happen to people. The original post was in February, and people are still picking up on it. My original culprit was Go Keyboard (the paid version "forgot" that I paid. When I refreshed it, the ad disappeared.)
    The next was Peel Smart Remote when it happened again.
    The article above was very helpful... it will probably happen again... Thanks, all!
    10-02-2016 02:49 PM
  5. lovedroid's Avatar
    I found the same thing this morning. I tracked it down to the zcamera, I installed. Uninstalled, and everything back to normal. Hope that helps!
    KennyS6 likes this.
    10-10-2016 12:30 PM
  6. JWall73's Avatar
    Uninstalling z camera fixed mine.
    10-21-2016 06:32 AM
  7. Subbu Arunachalam Sankara Narayanan's Avatar
    I followed the steps that UKGandalf suggested, closed all the applications, plugged in the charger, selected the button that lists the apps and in my case it showed PhotoCollage app. Apparently it had a check box in its setting to show rapid charger screen and it was selected. I unchecked the box, it worked for me.
    10-23-2016 10:53 PM
  8. stealthredhead's Avatar
    An annoying "Clean Master Boost" ad screen kept popping up on my new S7 Edge every single time I plugged the charger in. I uninstalled the Z Camera app, which by the way was already installed on my new phone from Best Buy, and now the ad is completely gone.
    10-25-2016 01:27 PM
  9. idauud's Avatar
    Just turn off the fast charging from right conner your phone will still be doing fast charging that is working for me. Thanks
    10-29-2016 01:45 PM
  10. Grejellybean's Avatar
    Just signed up to announce this happening during a recent app update, culprit was a superuser process, super user being installed via KIngo ROOT.
    10-31-2016 06:40 AM
  11. phissith's Avatar
    I had the same problem. Solve by uninstalling 1mobile market!
    11-03-2016 04:47 PM
  12. tijnbeschuit's Avatar
    That's weird, becouse i do not have ANY of those apps installed!
    11-04-2016 11:05 AM
  13. badryousef's Avatar
    thank you soooooooooooooo much you made my day it was a keyboard app I uninstalled it and it's worked !
    11-05-2016 08:35 AM
  14. TimAndroidNewbie's Avatar
    I've found the cause. It's the Go Launcher. So essentially if "Go Launcher"dev team said "hey we're going to homescreen you ads in exchange for a free really cool launcher". I would have been ok with that. But they didn't, so I went into "manage applications" and deleted it. Dragging the icon and deleting it that way won't work. I'm new to Android hence my handle so some of this might be redundant for you, my apologies. I still have Nova Launcher which seems ok.
    So you need to Go to Dev Options, Running services and select it, see if Charge locker services is on one of them. Delete the offending app or ask yourself if the ad is worth the free app you're getting, or if they offer a paid version which removes that ad, but question why a developer would sneak that in on the first place. I lost my respect for Go Launcher after this.
    11-05-2016 12:20 PM
  15. marti neurotic's Avatar
    Z Camera was causing the problem for me uninstalled and now is back to normal
    KennyS6 likes this.
    11-15-2016 04:24 PM
  16. Radar Rider's Avatar
    Thanks to all for this thread.
    I've been reading along since I was really getting tired of dealing with (2) lock screens on my HTC 10.
    The one that is supposed to be there and that annoying speed charge screen with the ads.
    Well I figured out that I had the Flash Keyboard on my phone.
    It wasn't being used but it was hiding in the background making ad money for someone out there.
    And some of those ads would lock me out unless I hit install but the always were blocked by the Avast antivirus I loaded early on.
    Avast could never find this little beauty though but this thread helped to get it off of the phone.
    So I'm very happy tonight!
    11-18-2016 08:17 PM
  17. Radar Rider's Avatar
    As I continue to read through the pages of this thread I see more and more apps with this little beauty buried inside.
    So this must be a very profitable venture for everyone involved!
    What a crock!!
    11-18-2016 08:20 PM
  18. anon(10103175)'s Avatar
    This is now part of ES File Explorer, in addition, it tries to get you to let it scan certain apps. It's SPAM! ES File Explorer used to be nice and non-invasive & non-spamming. Apparently those days are gone.
    12-07-2016 01:37 PM
  19. knitastrophe's Avatar
    Had this issue for a few days, finally drove me insane when I couldn't shut my alarm because ad was swipe to dismiss to get to homescreen. After finding this forum I've determined that it was a 4+ star app I downloaded for passport/licenses as I had just renewed my dl and my temporary was offered as a download.
    12-09-2016 07:39 AM
  20. Xarias's Avatar
    Thanks! I have that too and it was making me crazy!
    12-15-2016 03:06 PM
  21. Cates1994's Avatar
    I had the exact same thing and same screen. Awesome find for fixing. I just unistalled Zcamera and BAM...that annoying sped charge screen went away. TWO THUMBS UP!!!!!!!!!!
    Just tried everything everyone was posting on every site and THIS is what worked.
    Thank you so much!
    Had no issue with the screen other than the fact that it kept snoozing my alarms.
    01-02-2017 09:42 PM
  22. GrapplerScott's Avatar
    I've got the same issue. i did somehow get the Clean Master loaded, so i uninstalled it. But, the overlay speedcharger lockup is still there after reboot ... suggestions ??
    01-03-2017 09:54 AM
  23. Kinda121's Avatar
    I had same problem dont let S Photo Edit give notification if that fails uninstall it worked for me.
    01-19-2017 10:12 AM
  24. veronique198999's Avatar
    May I ask is there an app that could block the cellphone from charging?When the phone needs to be charge just unlock the app and charge can go.Thanks a lot!
    01-22-2017 09:47 PM
  25. CarlWayne29's Avatar
    I just turned off rapid charger, from the ad screen. Problem solved. I don't know where it came from, but I know it came with the phone.
    01-26-2017 04:00 PM
279 ... 89101112
  1. Replies: 4
    Last Post: 05-17-2016, 10:58 PM
  2. Replies: 9
    Last Post: 02-20-2016, 08:45 PM
  3. Replies: 2
    Last Post: 02-11-2016, 06:24 AM
  4. Replies: 26
    Last Post: 02-06-2016, 11:23 PM
  5. Replies: 1
    Last Post: 02-05-2016, 09:27 AM
