04-24-2018 11:43 AM
276 1234 ...
tools
  1. Mairzy Doats's Avatar
    So I started looking at what had been installed recently - deleted one rewards app, no luck. I worked backward until I noticed Go Launcher - and saw that it had an update on March 4th.
    I uninstalled.....The screen is now gone. Booooooo to the Go Launcher people.
    OK, I finally figured out why it's behaving this way: there is a new setting under Advanced, called 'Quick Charging'. I don't know what, if anything, this actually does, beyond setting up that ***obnxious*** fake lock screen.
    I do have a screenshot, but I can't figure out how to attach it via the mobile page.
    Newtonium likes this.
    03-25-2016 10:50 PM
  2. juliesdroidsync's Avatar
    Yes, if memory serves, that's about what my screen looked like... Do you use GoSMS text messaging? The last upgrade I did "lost the connection" to the fact that I had PAID for this app...
    03-26-2016 08:43 AM
  3. Alvin Au's Avatar
    may be a SOLUTION!
    hi everyone, i come across the same situation as you guys experienced. i deleted the APP " 頂尖開發人員 GO输入法国际版" (which is a keyboard input app for chinese. or you can find here https://play.google.com/store/apps/d....jb.gokeyboard). after 5 hours until now, it seems that it is work !
    i think " 頂尖開發人員 GO输入法国际版" must deal with some ad-selling unit to show the ad, so" 頂尖開發人員 GO输入法国际版"may not be the only APP which brings the problem. I suggest u guys to delete the APP which has share the same ad-system with " 頂尖開發人員 GO输入法国际版" (if you guys can find it out) or you guys should try deleting some APP which always lead to the ad problem. Also, since i downloaded and used " 頂尖開發人員 GO输入法国际版" for a long time, i dont think u guys should just focus on those APP that u downloaded recently.
    03-27-2016 04:58 AM
  4. Tonypal's Avatar
    Are these really solutions as I do not have the programs you mention, yet yesterday this started and I have not installed an app in weeks. I deleted all apps that I really do not need and still have the problem. It must have some timed delayed built into some app. Maybe set to so many days from installation? I tried the Stopbadap, Avast, and other cleaners, with no luck. If someone finds out the solution please post the step by step to get rid of this. obviously if there are a lot of people posting here, hundreds of thousands of people must have this problem!
    03-29-2016 06:48 AM
  5. Tonypal's Avatar
    Was this where you turned it off? It seemed to work for me, for now.... will check throughout the day.....been an hour, no lock screen ads.
    New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4-screenshot_2016-03-29-09-12-35.jpg
    03-29-2016 08:30 AM
  6. Tonypal's Avatar
    Forget that solution, just came back, very frustrated as I read in this thread they even did resets and it came back.
    03-30-2016 04:25 AM
  7. Tonypal's Avatar
    another possible solution?
    (yes, this is really bothering me, lol)
    New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4-boostchargelockscreen.jpg
    03-30-2016 06:28 AM
  8. Vonzy's Avatar
    Some days ago I removed Z Camera that was giving me this nasty thing:
    New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4-zero1.jpg
    On every app in Google Play its possible to make a report to Google, I did, and Z Camera is now removed from Google Play!!
    Zero Team still got some apps there: https://play.google.com/store/apps/d...id=Zero%20Team
    PLEASE!
    If you are finding some program that is malware or don't behave as it should
    -> REPORT TO GOOGLE!
    So we can get rid of all crappy apps!
    03-30-2016 12:04 PM
  9. Tonypal's Avatar
    I did not have that app, so it must be in different apps as well. I was able to swipe the top of the annoying lock screen and turn it off....
    03-30-2016 12:17 PM
  10. Vonzy's Avatar
    They seem to be in several apps and are very often hard to find, but when you find the app
    - REPORT IT TO GOOGLE,
    and 1.000's of people will get a better life!
    03-30-2016 12:22 PM
  11. Chris Winter1's Avatar
    Dont just Stop boost charge.
    You also need to un-install Touch Pal.
    That was the nasty for me.
    Touch Pal is a third party keyboard app but it seems that it sits there downloading more and more Touchpal versions.
    I've only had my phone for 2 days (ZTE Razor V Plus) and Touch Pal was installed out of the box.
    Last night it "updated" and suddenly I had 2 Touch Pal apps (keeping in mind I hadn't even used Touch Pal and had the phone set to default keyboard)
    After the update, plugged the phone in to charge and BOOM, Boost Charge Screen with ads.
    After some playing around I disabled it as you did, but then I removed Touch Pal (both versions) and the issue has not returned.
    I'm reporting this issue to ZTE as that's a very bad look to be installing Adware as core apps lol.
    Great phone other than that (he says on day 2).
    03-30-2016 07:27 PM
  12. Vonzy's Avatar
    Don't forget to report this directly to Google !
    03-30-2016 08:10 PM
  13. bsoplinger's Avatar
    It has to be part of some ad module a number of different 'brands' of apps are using. I have none of the above mentioned apps yet I too have this screen which for me showed up last evening, March 30th.
    Once I figure out which app is using this malware type ad module I shall report the app to Google. If enough app developers get their app flagged someone will blow the whistle and identify the ad module behind this which hopefully will be enough to kill it.
    03-31-2016 02:32 PM
  14. Mighty's Avatar
    Thanks to everyone who has provided clues in this thread.
    I had Quick Pic, a Cheetah Mobile gallery alternative. I removed that, but still saw the Quick Charge ad page.
    I've been using Go Launcher Z for years. Based on a clue here, looked in there. Under Advanced settings is a Quick Charge switch. Turned that off, and it appears to be gone.
    I think I paid for Go Launcher a long time ago. But, I don't see any indication one way or the other.
    There is a note in the "What's New" that v5.02 fixes a "didn't remove ads" bug. That's a typo, because I have v2.05. It looks like the Play Store has v2.1, but it's not offering to update on my phone, right now.
    Personally, I don't mind ad-supported software as long as the ads are restricted to the actual app itself. Any pop-up ad over any other app, I consider to be adware. Popping up a swipe lock screen counts as adware, to me. I've become very comfortable with Go Launcher. But, this form of adware is going to make me re-think that choice.
    Drake Christensen
    03-31-2016 10:09 PM
  15. Bradley Bahler's Avatar
    I had two new battery lockscreen problems. Try this. When the lockscreen is displaying, at the bottom of the screen hit the android icon for recent apps, (on my Nexus 5x it's a square on the right). The lockscreen should minimize showing the app it is associated with. Either uninstall the app or check it's settings to disable the battery charging lockscreen. The two apps that were secretly launching my lockscreens were Next Launcher Lite and Kitty Play wallpapers.
    04-01-2016 04:32 AM
  16. mikejbrady's Avatar
    Absolutely correct for that screen shot: TouchPal.
    To disable:
    Settings > Language & Input > TouchPal
    Menu (upper left) > Settings > Boost Charge (very bottom)
    It's a fantastic keyboard, but the ads are killing me. They get worse with every release. Premium? $5/year is steep. I'd do $5 once or maybe $2/year. Feels silly to write that, but if every app and useful site was $5/year, ouch. Thinking it may be time to look at the current crop of options.
    04-01-2016 05:16 AM
  17. tommyp86's Avatar
    I had the same lock screen randomly appear, Super Battery by KingoApp was the cause of mine. Some apus crap got in there
    New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4-screen_1.jpg
    heres the apus packages I found in the androidmanifest:
    com.apusapps.charging
    com.apusapps.battery.ChargingActivity
    com.apusapps.battery.ChargeFastGuideActivity
    com.apusapps.battery.ChargingCoreService
    04-01-2016 06:10 PM
  18. Traumtanzer's Avatar
    Spent forever trying to track this down, want to thank everyone who's contributed to this thread as the information here helped a great deal.
    To clarify, my issue was with Speed Charger, the one with the liquid level display. I finally tracked this back to Go Weather Ex, a program that I'd bought quite a while back. The charger lock screen suddenly appeared today, and appeared on both my phones, a V10, and an S7 Edge (personal and work phones), so I knew it wasn't manufacturer specific and must have been related to some app installed in both places. The way I stumbled onto which app was to turn off the unlock screen on my S7, then hold the app history button, which popped up a brief message that Go Weather Ex didn't support split screen viewing. I verified this by uninstalling Go Weather Ex, verifying that the Speed Charger screen was gone, then reinstalling Go Weather Ex to verify that it was back. As has been mentioned, this was a purchased program that didn't detect that it was purchased when reinstalled, which caused the ads on the lock screen overlay, but verifying premium only took away the ads from the lock screen, not the screen itself. I could find no reference to the speed charger screen or function in the Go Weather Ex menus.
    This behavior concerns me on several levels.. A program that interferes with the function of a device and will not identify it's origin is a malware program to me, and it seems like Go has gone out of it's way to hide where this screen is coming from. The slide to unlock on top of whatever actual lock on the phone seems to be a gimick to make sure you have to look at the ads and/or accidentally click on one while you're trying to get your phone to work. On top of that, I find it hard to believe that a program working from the app level is going to have any effect on low level fast charging on newer devices, I could be wrong, of course, but it smacks of snake-oil system cleaners of the PC world that say they are making your system run faster, but do nothing more than display messages that your system is running faster.
    This is definitely a hit on the Go team's reputation for me. I hope that this will help someone else track down this annoying lock screen.
    04-01-2016 07:52 PM
  19. Mighty's Avatar
    I sent feedback to Go, telling them that I regard those ads as adware, and that I would no longer recommend their program, until they removed that ad system. And, that they should review whatever process they used to decide to do that, and change it, so that they don't do anything like that, again.
    04-01-2016 08:15 PM
  20. brisqueen's Avatar
    I would check any apps with themes or wallpapers. I had the same problem. KittyPlay was the culprit. Checking your running apps will allow you to find the problem, good luck.
    Trantor_oz likes this.
    04-02-2016 12:35 AM
  21. thegoodladybelvoir's Avatar
    This was happening on my Galaxy Note 5.
    04-02-2016 12:08 PM
  22. thegoodladybelvoir's Avatar
    Yes - Kitty Play from Home Plus was what was causing it on my phone. I'd updated my apps earlier in the day yesterday and then the lock screen appeared a couple of hours later. Once I removed the app, the lock screen went away.
    04-02-2016 12:19 PM
  23. tommyp86's Avatar
    Do any of you guys know where/from who this crap originated on your, im thinking instead of reporting possibly 100s of apps that are, most likely, unintentionally having this issue, it would be best to report the source.
    Mine was Apus, which Im betting thats the root of the issue. If its confirmed though, Id say its safe to assume theyve exploited a backdoor, thats disturbingly common across apps in the playstore.
    04-03-2016 02:40 AM
  24. ReseStenson's Avatar
    KittyPlay was the culprit, not GO.
    04-04-2016 01:32 PM
  25. Vonzy's Avatar
    There is a diffrence between Android and Windows
    On Windows there is 100's of files to a program that ends up in several places where a single program can affect everything on the computer = almost impossible to know where the virus/malware is.
    Android's apps are running from only 1 folder and it's apk-file and got very hard to affect something more.
    - So always report to Google when you find apps that behaves like this!
    04-04-2016 02:06 PM
276 1234 ...
  1. Replies: 4
    Last Post: 05-17-2016, 09:58 PM
  2. Replies: 9
    Last Post: 02-20-2016, 07:45 PM
  3. Replies: 2
    Last Post: 02-11-2016, 05:24 AM
  4. Replies: 26
    Last Post: 02-06-2016, 10:23 PM
  5. Replies: 1
    Last Post: 02-05-2016, 08:27 AM
