01-03-2019 01:47 AM
279 ... 23456 ...
tools
  1. lanhchuachaplin's Avatar
    They seem to be in several apps and are very often hard to find, but when you find the app
    - REPORT IT TO GOOGLE,
    and 1.000's of people will get a better life!
    How to report it directly to Google?
    The only thing that I did was to uninstall Go keyboards and that ads screen is gone. I want to report this app.
    This kind of app devs is unacceptable.
    04-14-2016 12:57 AM
  2. Vonzy's Avatar
    This is possible on all apps, scroll down In Google Play on the app and there is the text: Report, click on that link and you will end up on the place where to report.
    - Hopefully, it will make Go to become Gone ;-)
    04-16-2016 01:45 PM
  3. calred34's Avatar
    In my case it was Go SMS Pro. Been (was) using it for a long time and never had an issue. Google Play reports it was updated on 1 Apr2016 - I certainly don't see ANY notification in there that this crap was being added! I've taken it out and no more problem ... Now I'm looking for a new text messaging app ... I'll be reporting it as well.
    04-16-2016 02:06 PM
  4. Daelsion's Avatar
    My problem was with Go Keyboard...
    04-17-2016 04:16 AM
  5. Trigati's Avatar
    Go Launcher has always been filled with adware, even just ads for other junk they make. There are so many better launchers available that don't add extra junk you don't want and didn't expect.
    Sent via the Communications Center of the Trigati
    04-17-2016 10:35 AM
  6. Theme Mizer's Avatar
    I also found that Kitty Play as the culprit. I still have it installed but, blocked permissions and notifications. Haven't seen the screen since on either my S7 or Note 3.
    ivybrog likes this.
    04-18-2016 07:48 AM
  7. Mark Embacher's Avatar
    For me it was GO Keyboard. Uninstalled one app at a time. Speed Charge disappeared after uninstalling GO Keyboard. Shameful misrepresentation.
    04-19-2016 02:03 PM
  8. ivybrog's Avatar
    Are these really solutions as I do not have the programs you mention, yet yesterday this started and I have not installed an app in weeks. I deleted all apps that I really do not need and still have the problem. It must have some timed delayed built into some app. Maybe set to so many days from installation? I tried the Stopbadap, Avast, and other cleaners, with no luck. If someone finds out the solution please post the step by step to get rid of this. obviously if there are a lot of people posting here, hundreds of thousands of people must have this problem!
    Uninstalling KittyPlay did it for me!
    04-20-2016 02:44 AM
  9. ivybrog's Avatar
    I uninstalled KittyPlay....BINGOOOOOO
    04-20-2016 02:47 AM
  10. HDE2011's Avatar
    figured it out , was driving me mad...under more networks
    New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4-screenshot_2016-04-21-01-19-30.jpg
    04-21-2016 02:24 AM
  11. jtizzleholla's Avatar
    Me too! Wow thank you!
    I have a Nexus 6p - The stock camera ap isn't very good. Know of a good one that doesn't have adware? I don't mind paying a few bucks.
    04-22-2016 10:35 AM
  12. Kimberly Thomas2's Avatar
    What if you don't have a the Clean Master app on your phone?
    04-22-2016 12:38 PM
  13. joenforcer's Avatar
    I just got this with the Amber Widget 2.2.3 update on 4/21/16. Either don't update or uninstall; there's no way to turn it off.
    04-22-2016 03:51 PM
  14. gooseman47's Avatar
    So, 2 days ago, a new lock screen "on top of" my regular lock screen "magically appeared" on my Note 4.
    It shows time/date in upper left corner, and a ... menu in the upper right that allows me to turn off speed charging. Then, a % charged indicator, and underneath that, some annoying ad... at the bottom, there is a "slide to unlock", which then goes to my Nova Launcher lock screen, which I have setup with my fingerprint scanner.
    So basically, now I have to go through an additional lock screen and view an annoying ad to get into my phone.
    I have no idea where this came from, and to the best of my recollection, I haven't added any new apps.
    Any idea how to get rid of this?
    Thanks for your help!
    I had the same problem and found it was the Go keyboards that were causing it. If you're using Go keyboards try uninstalling and check.
    04-22-2016 11:18 PM
  15. Tim Reczek's Avatar
    For me the issue was ES App Locker, but the real culprit is one of the Ad Networks that I suspect many of these apps are all using.
    You can see all the Ad Networks your applications use through program called Addons Detector (there may be others but this one worked for me).
    1. Install Addons Detector from Google Play
    2. Run a scan (it will update it's database the first time)
    3. When the scan finishes click the big green Addons button
    4. In the Addons screen select Advertising from the filter drop down
    ES App Locker uses only two Ad Networks AdMob and Facebook Audience, so I suspect one of these is the culprit.
    On my Nexus 9 AdMod is also used by:
    • ES File Explorer
    • PowerPoint
    • Word
    and Facebook Audience is used by:
    • App Cache Cleaner
    • ES File Explorer
    • Scrabble
    • Spider
    However, at the moment, uninstalling ES App Locker did the trick even though the other apps above also use the same ad networks. It's possible that there are different subscription options that app developers can select from when they use the networks which may explain why some apps using these ad networks cause the problem and others do not (at least for now). Or possible it's something that this new behaviour is getting rolled out by the ad network gradually across all the apps using it.
    Either way I'd be interested to hear what ad networks the other programs that people have identified as causing this same issue use.
    Hope this helps,
    Tim
    Javier P likes this.
    04-24-2016 09:50 AM
  16. omriamos's Avatar
    This is from TouchPal keyboard. I installed it yesterday and it started since then.
    I uninstalled it and it's gone.
    04-24-2016 05:51 PM
  17. SAGEBRUSH55's Avatar
    I too just started receiving this last night.. It is so annoying...
    04-25-2016 03:56 PM
  18. SAGEBRUSH55's Avatar
    Just figured out it was the New Theme I added from GO SMS.. Deleted it and now its gone..
    04-25-2016 04:14 PM
  19. rob9983's Avatar
    Go Keyboard got me with the Speed Charge lock screen also. I guess no Go products can be trusted any longer.
    04-25-2016 04:21 PM
  20. Shelly H's Avatar
    Thank you all so much! Was tryin' hard to figure out what this Speedcharge garbage was. Uninstalled Z camera, problem solved!
    04-27-2016 03:04 PM
  21. MomoMilky's Avatar
    I noticed this a few days ago on my mom's Note4 when it was charging. Culprit was GoSMS. Uninstalled it and the lock adware screen went away. Now I installed Textra on her phone to use instead.
    04-27-2016 04:42 PM
  22. Uglytuc's Avatar
    Yep it was GOSMS Pro for me as well. An app that I have been using for years with no issues. Not only is that screen annoying but also dangerous as it would disable my alarm which is a very strange behavior.
    04-29-2016 02:03 PM
  23. 49er_PhD's Avatar
    Go Keyboard was the culprit for me. I'd even pay for Go to make their adware go away but they don't seem to offer that option.
    05-02-2016 02:58 PM
  24. anon(9903882)'s Avatar
    uninstalled GO weather X and the horrible adware swiftcharge lockscreen disappeared. Thanks to all in this thread for helping me solve this.
    05-03-2016 01:23 AM
  25. carolzdiet's Avatar
    I had this one too. Deleted several apps. Nothing worked till I deleted what I always thought was a GREAT app. ADVAST! The screen went away. Now..who knows, it might come back...but for now it is gone.
    Carol
    05-03-2016 03:46 AM
279 ... 23456 ...
  1. Replies: 4
    Last Post: 05-17-2016, 10:58 PM
  2. Replies: 9
    Last Post: 02-20-2016, 08:45 PM
  3. Replies: 2
    Last Post: 02-11-2016, 06:24 AM
  4. Replies: 26
    Last Post: 02-06-2016, 11:23 PM
  5. Replies: 1
    Last Post: 02-05-2016, 09:27 AM
