01-03-2019 01:47 AM
279 ... 45678 ...
tools
  1. foxemerson's Avatar
    Removed EZ file explorer and problem gone. I guess EZ file explorer probably lost a few hundred customers with this dumbass idea. Lost me for life that's for sure.
    05-11-2016 04:23 PM
  2. ravenmoon50's Avatar
    A very strange thing happened to me when I was updating some apps:
    The app New Airpush Detector was also installed!
    - Could it have been Google? Because I have reported two apps?
    . . . . . . . http://i.imgur.com/Nb8GaeQ.jpg
    I have tried it, and it works fine!
    https://play.google.com/store/apps/d...rc.ap.detector
    New Airpush Detector will detect which application is integrated with Airpush and detailed status like smart wall ads , push icon ads, push ads status. You can click an application to open setting and uninstall that application.
    # Important #
    This app may find Facebook,eBay,twitter as 'Airpush ad publisher' because these app uses same mechanism as airpush to push notification on your device.
    Some apps got a note about "Airpush Detected", one is from my Bank ;-)
    and some is internet-radio apps - nothing dangerous
    I hope that this will work for all of you that can't find the app that is messing it up!
    I installed it and checked, and they said that tumblr is a problem because it has push ads..could it be true? I don't want to delete that app because I like it but the fact that boost battery app pops up on lock screen really worries me
    05-12-2016 02:12 AM
  3. Ad1na's Avatar
    It was es file Explorer for me, thanks.
    I uninstalled it and boosting charge and ads disappeared.
    Thanks
    Dj_musso likes this.
    05-12-2016 02:22 AM
  4. daradroid's Avatar
    disabling Charging boost stopped the ads. Thx!
    05-12-2016 06:02 AM
  5. matt.t.martin's Avatar
    Same thing happened to me after an update in the last few days.
    ES File Explorer - *DELETED*
    05-12-2016 05:03 PM
  6. Dj_musso's Avatar
    I got the sAmerican thing. ES file Explorer recently updated and added a bunch of new features and took the liberty of activating them all. If you have that app, that is most likely where it came from. Today I pressed the wake button to my phone and discovered that the lock screen had changed to a blue liquid that corresponded the percentage of my battery. Also had an advertising, was able to disable it through the menu button on the top right corner. Also noticed on the notification tray was a button that said allow special permissions. When I clicked on it it launched ES File Explorer. HOPED THIS HELPED!!!
    This fixed it on my phone as it had a tab to turn on and off the fast charge and i deleted the app too lol
    05-12-2016 06:24 PM
  7. anon(5477192)'s Avatar
    saw some posts on Reddit that it comes back on by itself.
    05-12-2016 08:23 PM
  8. oi_you_nutter's Avatar
    Thanks for the help/suggestions
    A bunch of apps on my LG G2 updated yesterday, I have none of the ones that others mentioned: the only two that were not Google products were Skype and the HHonors (Hilton) app... So I uninstalled them both as I had already spent 20 minutes or more hunting for a solution
    No battery monitor lock screen appeared after the restart, so I guess it was either Skype or HHonors.
    Cheers
    Tim
    05-14-2016 11:38 AM
  9. Dynamodaveb's Avatar
    Mine looks different but similar with same issue, cant figure out how to get rid of it.
    05-14-2016 12:52 PM
  10. Martin_G's Avatar
    Having the same issue, still can't find the app that's causing it I have never used any on previous lists,
    Any way to find out which app rather than deleting one by one.
    05-14-2016 02:45 PM
  11. Suleman Hasib's Avatar
    Yes Indeed it was ES File Explorer
    Goto tools and disable charging boost.
    Laura Knotek likes this.
    05-14-2016 05:19 PM
  12. NexusGirlX's Avatar
    ES File Explorer here as well. Froze the app with Titanium Backup and the nasty lockscreen was gone.
    I didn't see an option to disable the "speed charging" as the poster above.
    Reported the app to Google. I used to love ES File Explorer and have it on all my devices...but this is too much. Viable alternatives?
    I had this for the first time as well on my Note Edge yesterday. I don't need ES File Explorer since I have My files which is included anyways.
    My Files works great.
    05-14-2016 06:46 PM
  13. Laura Knotek's Avatar
    I use Total Commander. https://play.google.com/store/apps/d...TotalCommander
    05-14-2016 06:49 PM
  14. twinkmot's Avatar
    Mine was from ES explorer. On one system update recently, all apps updated, Nexus 7 restarted, and I was asked if I wanted to enable quick charge. I did, thinking it was the new android feature. Today, the annoying lock screen and the ad at alarm. Disabled the charge booster in ES Explorer. How sneaky!
    05-16-2016 03:45 AM
  15. Billie 1's Avatar
    I didn't see the app that was causing my lock screen either but I went to my phones active applications that are running in the background and found an app called photo editor pro that was running so I uninstalled it and sure enough that was the culprit!
    Heres a link to the app
    https://play.google.com/store/apps/d...in.photoeditor
    05-16-2016 03:51 PM
  16. Sebbos's Avatar
    Thanks! That did it for me
    05-16-2016 06:12 PM
  17. NexusGirlX's Avatar
    Not enough people are paying for the full versions of their apps so they are trying to force things on us such as this charging screen with ads on it.
    They're just going to upset a lot of people who will end up removing this garbage.
    05-16-2016 08:10 PM
  18. Mary Johnson7's Avatar
    So, 2 days ago, a new lock screen "on top of" my regular lock screen "magically appeared" on my Note 4.
    It shows time/date in upper left corner, and a ... menu in the upper right that allows me to turn off speed charging. Then, a % charged indicator, and underneath that, some annoying ad... at the bottom, there is a "slide to unlock", which then goes to my Nova Launcher lock screen, which I have setup with my fingerprint scanner.
    So basically, now I have to go through an additional lock screen and view an annoying ad to get into my phone.
    I have no idea where this came from, and to the best of my recollection, I haven't added any new apps.
    Any idea how to get rid of this?
    Thanks for your help!
    8
    Answer: you have to go to the settings when that screen pops back up and uncheck the lock screen I just saw it today and thought I had spam on my phone. I dont know where it came from either
    05-16-2016 08:11 PM
  19. sure why not's Avatar
    NGX,
    I pay for the 'Pro' versions of most applications and reward/donate to many devs for their roots, roms, etc.
    Sneaking this **** onto people's devices is not the way to make a buck.
    I'm definitely blacklisting ES and anyone else participating in this nonsense.
    NexusGirlX likes this.
    05-16-2016 08:41 PM
  20. avisen's Avatar
    The popup showed up a few days ago but me, being a new android user, decided it may have been normal. But the ads put me off and I was scared of viruses/adware. I ended up checking Photo Editor Pro and, lo and behold, it was there. I really liked that app too. Oh, well.
    If you can't find it, check every app's settings or delete any new apps. I thought it was Amazon Video since I downloaded it from Amazon and not the Store. Guess not.
    05-16-2016 10:33 PM
  21. Raetor75's Avatar
    It was Photo Editor Pro for me. Wish I would have started on the last page of this post. Thanks for the help. That was driving me nuts.
    05-16-2016 11:04 PM
  22. Elina_87's Avatar
    I got rid of the lock screen by uninstalling a keyboard app called Kika Keyboard. My lock screen didn't say anything about words typed today as someone else's did, but this still did the trick for me. Hope this helps someone else battling with the same annoying lock screen.
    05-17-2016 01:15 AM
  23. StephenCWLL's Avatar
    Sigh. Just noticed this lock screen today. I've not got ES File Explorer or Photo Editor. It could have been around for ages but only just noticed it.
    This is what my lock screen looks like ...
    New Speed Charge/Battery Status Lock Screen with annoying ads "just appeared" on GN4-media-20160517.png
    05-17-2016 06:39 AM
  24. Name Surname's Avatar
    @StephenCWLL Do you have Photo Collage Editor app installed?
    05-17-2016 09:15 AM
  25. tossero's Avatar
    This was the culprit for me , you only have to uncheck the "charging Lockscreen option" from the PhotoColage or Photo Editor pro app.
    Thanks ~
    05-17-2016 10:09 AM
279 ... 45678 ...
  1. Replies: 4
    Last Post: 05-17-2016, 10:58 PM
  2. Replies: 9
    Last Post: 02-20-2016, 08:45 PM
  3. Replies: 2
    Last Post: 02-11-2016, 06:24 AM
  4. Replies: 26
    Last Post: 02-06-2016, 11:23 PM
  5. Replies: 1
    Last Post: 02-05-2016, 09:27 AM
