09-23-2018 11:30 AM
278 ... 7891011 ...
tools
  1. candiedchristine's Avatar
    The culprit for my wife was the Flash Keyboard, once removed it ceased the screen in question.
    I am the wife in question. I found the solution from a reddit forum: https://www.reddit.com/r/galaxynote5...g_lock_screen/
    07-24-2016 10:41 AM
  2. Golfdriver97's Avatar
    Not often we have both spouses in the forums. Was the app intentionally installed?
    07-24-2016 11:06 AM
  3. candiedchristine's Avatar
    I did not install it, so it was either bloatware or was installed when Google & Samsung were updating various apps.
    And I found a really good article on why Flash keyboard is so bad. https://www.androidpit.com/flash-key...hould-avoid-it
    07-24-2016 11:52 AM
  4. Riya Bhasin's Avatar
    None of these suggestions have gotten rid of this screen for me, unless I missed something. Has anyone done anything that actually works for this issue specifically?
    I only get this screen when I plug my phone in to charge
    Hey, i had the exact same thing which i just turned off. Essentially, to turn it off, tap on the three vertical dots in the top right corner of your screen and tap turn off speed charge. That turned it off for me!
    07-26-2016 07:44 AM
  5. Moto_X_Fan's Avatar
    How do I get my charging screen back On? I had closed it with the settings"gear", but now I have uninstalled the offending app causing the ads. I always liked the liquid blue bubble charging screen, until the ads appeared.
    07-27-2016 04:02 PM
  6. daveneo6's Avatar
    For me it was flash keyboard as well. I recently factory reset my phone. I was able to go into developer options and select the running services button and noticed something from flash about battery charging.
    The crazy thing is I didn't have anything from flash keyboard installed on my phone. I went to the play store, installed flash keyboard and then uninstalled it and now it's gone.
    Hopefully this helps someone else out! It wasn't an "Installed" program from what I can tell however after installing flash their uninstaller removed it.
    07-27-2016 04:32 PM
  7. Josh Wells3's Avatar
    I don't know if you fixed it yet but mine done that. I deleted flash keyboard and it went away
    08-05-2016 06:59 PM
  8. Mexicanadian's Avatar
    Like you, I used go sms. But it stopped working and i deleted it, only to not delete the go keyboard app. Once i did, the second lock screen went away. Its total bs that this happens. Thanks for your help, cheers!
    08-09-2016 01:29 AM
  9. lizard9's Avatar
    I had this problem and I was wondering if anyone has any Go keyboard, because after I deleted that from my phone it stopped happening.
    08-09-2016 12:40 PM
  10. eman1138's Avatar
    After many hours of reading forums and trying to find the culprit, I finally found the name of the app that was causing the annoying "battery charging" lock screen. I thought you might like to add it to the list, since I haven't seen it mentioned on any other forums yet.
    Flash Keyboard
    That seems to be the cause, as soon as I removed it, I no longer have that extra battery lock screen.
    08-09-2016 02:29 PM
  11. arwin009's Avatar
    I had exactly the same problem with charge boost screen, but immediately after uninstalling GO Keyboard this screen disappered. So this crappy GO Keyboard is causing the problem. I reported this app to Google.
    08-18-2016 11:14 AM
  12. NexusGirlX's Avatar
    They're not breaking any rules by having ads in their app. Use an adblocker and you won't see any ads. I use Adaway to block all ads in apps.
    08-18-2016 11:16 AM
  13. Jessicamk07's Avatar
    I just uninstalled my go keyboard and that screen is gone.
    So, 2 days ago, a new lock screen "on top of" my regular lock screen "magically appeared" on my Note 4.
    It shows time/date in upper left corner, and a ... menu in the upper right that allows me to turn off speed charging. Then, a % charged indicator, and underneath that, some annoying ad... at the bottom, there is a "slide to unlock", which then goes to my Nova Launcher lock screen, which I have setup with my fingerprint scanner.
    So basically, now I have to go through an additional lock screen and view an annoying ad to get into my phone.
    I have no idea where this came from, and to the best of my recollection, I haven't added any new apps.
    Any idea how to get rid of this?
    Thanks for your help!
    08-20-2016 08:33 PM
  14. steveschoen's Avatar
    How do I get to "advanced setting". I have this same "charging lock screen" come up. I have no KittyPlay. I have no Go software that I know of. I have a Samsung Galaxy S5 phone.
    08-30-2016 05:58 AM
  15. TutTLe Siu's Avatar
    Mine was caused by the Go Weather App. Uninstalled, and everything is good. Thanks for the heads up!
    Mine is the Go Weather App too, and I've just uninstalled it n reported it to the GoWeather on google play about it, hope this help to the other ppl.
    N thanks for the heads up buddy.
    09-03-2016 07:44 AM
  16. PhysioBean's Avatar
    Hi, i have had the same problem. For me it was Kika Cute Keyboard. I have the Pro version of Kika and that's ok, its the free cute keyboard which states it comes with ads. Did what another member stated, checked which apps were used over past 3hrs whilst charging and Kika Cute Keyboard was the culprit, all is back to normal now. 😁
    09-03-2016 10:49 PM
  17. tommyscottrocks's Avatar
    It came with the latest Marshmallow update. I haven't figured out how to get rid of it yet.
    09-05-2016 11:00 AM
  18. djstretch's Avatar
    I just deleted Applock Pro and it fixed my problem
    09-15-2016 01:39 PM
  19. Sls8531's Avatar
    OK, I finally figured out why it's behaving this way: there is a new setting under Advanced, called 'Quick Charging'. I don't know what, if anything, this actually does, beyond setting up that ***obnxious*** fake lock screen.
    I do have a screenshot, but I can't figure out how to attach it via the mobile page.
    Problem solved for me. I was getting the fake lock screen only after charging my phone. I found an app called flash keyboard running which I noticed wasn't under my default apps but showed under all apps. I uninstallled it. Plugged my phone into charge for a bit and the fake screen no longer shows after charging.
    I've been frustrated for two days trying to figure it out. It's adware that went undetected by Malwarebytes and Kapersky Antivirus I installed on my Samsung Galaxy 7. It may not be the same app as the one I found as there are so many out there but my suggestion is go thru your apps carefully. I clicked on each one to see if it was a system default or actual app. You can tell the difference by the options it shows. If it's system you can only force stop or disable. Installed app you can force stop, uninstall. Good luck!
    09-16-2016 10:33 PM
  20. Eight2L8's Avatar
    It took me days to figure out what was causing the extra lock screen on my phone. It's really weird how many different apps is causing this issue. It ended up being Flash Keyboard on my phone. Not even sure how that app got on my phone since I use SwiftKey. It would pop up with a blue screen and bubbles with advertisements every time I hooked my phone to fast charger.
    Saaaameee. Flash was it, never used it once. Cane from the samsung essentials store.
    09-21-2016 09:33 AM
  21. ken_z's Avatar
    Did you happen to get a new battery? This exact thing happened to me when I got a new Anker battery for my Note 3. When that charging screen pops up there should be a little settings gear in the top right corner..click that and it will take you to a settings menu...there should be an option that says "Charging LockScreen" it also says underneath that it will help charge your phone faster by havinv this. Anyways if you want the ads gone then click the box that should already be checked to the right. When I did this the ads went away but my battery percentage actually started going down while on the charger. And I couldn't find that settings menu anywhere on my phone.
    09-22-2016 10:11 PM
  22. 240Drift's Avatar
    Made an account to reply to this. My "2nd" lock screen looks like some of the ones posted, with the ad at the bottom. I knew mine was from CM Cleaner. At the top right of this screen it even showed Clean Master. After reading your comment I had a button on the top right of my screen as well. Once I pressed it another screen came up showing this feature is called, this is how it read on my phone, Charge Master ( contains ads) .
    I disabled it and now I am waiting to see if my phone charges faster. Before this screen it seemed like it would only take about a hour, but with the screen it would show a full charge would take almost 3 hours.
    09-24-2016 09:44 AM
  23. cajun dee's Avatar
    you. might have wthe app clean master, r DU lock screen , r one of there launchers
    09-28-2016 08:18 AM
  24. UKGandalf's Avatar
    Had this pop up on my wife's phone (Galaxy S3 on Android 4) today... found what was causing it this way:
    1. Plugged phone in to get screen to pop up
    2. *Did Not* swipe but instead pressed and held the home button to get the recent apps
    3. Tapped the pie chart in the bottom left to show active processes
    4. As this battery lock screen advert was the only thing running at the time it showed the "Flashlight" app responsible!
    5. Removed "Flashlight", restarted and plugged back in to test: Nothing popping up any more
    As you can't access current active processes the same way on Android 5 (have to go into settings first and it shows everything running rather than currently active) I still haven't found which app is doing this on my son's Moto G or daughter's Xperia M4 Aqua so if anyone can point me in the right direction of a similar screen in Android 5 if it still exists there I'd appreciate it!
    09-28-2016 12:37 PM
  25. hodag007's Avatar
    Mine is coming from a free install of AVG
    09-29-2016 10:40 AM
278 ... 7891011 ...
  1. Replies: 4
    Last Post: 05-17-2016, 09:58 PM
  2. Replies: 9
    Last Post: 02-20-2016, 07:45 PM
  3. Replies: 2
    Last Post: 02-11-2016, 05:24 AM
  4. Replies: 26
    Last Post: 02-06-2016, 10:23 PM
  5. Replies: 1
    Last Post: 02-05-2016, 08:27 AM
