X-1000!ES File Explorer here as well. Froze the app with Titanium Backup and the nasty lockscreen was gone...
Reported the app to Google. I used to love ES File Explorer and have it on all my devices...but this is too much. Viable alternatives?
X-1000!
I went a step further and un-installed from all my family's devices.
I don't mind paying a few bucks for a useful app.
An ""app"" that surreptitiously puts adware on my wife and kids devices?
.....go die in a fire ES.
I got the sAmerican thing. ES file Explorer recently updated and added a bunch of new features and took the liberty of activating them all. If you have that app, that is most likely where it came from. Today I pressed the wake button to my phone and discovered that the lock screen had changed to a blue liquid that corresponded the percentage of my battery. Also had an advertising, was able to disable it through the menu button on the top right corner. Also noticed on the notification tray was a button that said allow special permissions. When I clicked on it it launched ES File Explorer. HOPED THIS HELPED!!!
Yes, it was ES File Explorer. Will be letting them know how unappreciative I am of this.
So, 2 days ago, a new lock screen "on top of" my regular lock screen "magically appeared" on my Note 4.
It shows time/date in upper left corner, and a ... menu in the upper right that allows me to turn off speed charging. Then, a % charged indicator, and underneath that, some annoying ad... at the bottom, there is a "slide to unlock", which then goes to my Nova Launcher lock screen, which I have setup with my fingerprint scanner.
So basically, now I have to go through an additional lock screen and view an annoying ad to get into my phone.
I have no idea where this came from, and to the best of my recollection, I haven't added any new apps.
Any idea how to get rid of this?
Thanks for your help!
I don't think that it is Samsung. I started getting the same screen last night and I have been following this string all day. I got about 18 updates last night in Play Store and I didn't start seeing the blue speedcharge screen until after that. Finally went into my applications manager and looked for apps that did not down load and the only ones that I saw came from the virtual reality software that came with the phone (Galaxy S7). It was Cirque du Soleil and Strangers. I uninstalled those along with some camera apps that I had like Bestie and Z Camera and the problem seems to be solved. I just don't know which apps were causing the problem. I did do some research on the Cirque du Soleil and Strangers apps and they seem to be legit. The camera apps that I uninstalled did update right before I started seeing that blue screen though. I hope this helps.
None of these suggestions have gotten rid of this screen for me, unless I missed something. Has anyone done anything that actually works for this issue specifically?
I only get this screen when I plug my phone in to charge
A very strange thing happened to me when I was updating some apps:
The app New Airpush Detector was also installed!
- Could it have been Google? Because I have reported two apps?
. . . . . . . http://i.imgur.com/Nb8GaeQ.jpg
I have tried it, and it works fine!
https://forums.androidcentral.com/e...etails?id=com.abrc.ap.detector&token=_xcpKORS
New Airpush Detector will detect which application is integrated with Airpush and detailed status like smart wall ads , push icon ads, push ads status. You can click an application to open setting and uninstall that application.
# Important #
This app may find Facebook,eBay,twitter as 'Airpush ad publisher' because these app uses same mechanism as airpush to push notification on your device.
Some apps got a note about "Airpush Detected", one is from my Bank ;-)
and some is internet-radio apps - nothing dangerous
I hope that this will work for all of you that can't find the app that is messing it up!
