StephenCWLL
Ahh, yes, I do.
Got rid of it now. I rarely use it anyways. Hopefully this will be the end of that lock screen
So, 2 days ago, a new lock screen "on top of" my regular lock screen "magically appeared" on my Note 4.
It shows time/date in upper left corner, and a ... menu in the upper right that allows me to turn off speed charging. Then, a % charged indicator, and underneath that, some annoying ad... at the bottom, there is a "slide to unlock", which then goes to my Nova Launcher lock screen, which I have setup with my fingerprint scanner.
So basically, now I have to go through an additional lock screen and view an annoying ad to get into my phone.
I have no idea where this came from, and to the best of my recollection, I haven't added any new apps.
Any idea how to get rid of this?
Thanks for your help!
GO Keyboard is also causing this lock screen. A continuous running process of the app is labelled ".chargelocker", so if you have the lock screen issue and don't have any app on this thread, try looking for a similarly named process under the "running" tab in your app settings.
None of these suggestions have gotten rid of this screen for me, unless I missed something. Has anyone done anything that actually works for this issue specifically?
I only get this screen when I plug my phone in to charge
I have the same thing but if you press he gear icon on the top right hand corner and unchecked the box problem solved
