1. AC Question's Avatar
    If I push the remote I am unable to do anything on my phone. I can't even turn it off. I have to remove the battery
    02-08-2016 10:35 AM
  2. Javier P's Avatar
    It's a known issue affecting many users. The culprit is an app called Peel Smart Remote. Search for it in your app manager and disable it.
    02-08-2016 10:38 AM
  3. nuangel2's Avatar
    I had same issue few days ago .it had suddenly appeared .it is that app and and you need to go to application manager and disable it.i disabled it on my note4 and that resolved the issue for me.
    02-08-2016 05:08 PM
  4. pduffer's Avatar
    If you actually use the Peel app and don't want the widget to show, turn it off in the Peel settings.
    02-09-2016 12:13 PM
  5. mrmoe110's Avatar
    I probably use the Peel Remote app more than my regular remote lol. The IR blaster is one feature that people never talk about, but its one of the main things that's keeping me using the Note 4.
    kpdx likes this.
    02-09-2016 01:48 PM
  6. Kwahme Cole's Avatar
    They push an update for the app today. But ditto to what everyone else said
    02-09-2016 10:16 PM
  7. NotAnAppleGuy's Avatar
    Never used it before now the icon all of a sudden shows up on my lock screen.
    Posted Via Galaxy Note Edge. Yea, the phone is perfect...
    02-09-2016 10:19 PM
  8. MissMy1's Avatar
    Thank you guys, it has been bugging me for 2 days and I couldn't work out where it came from..
    Cheers!
    02-09-2016 11:49 PM
  1. Dual booting IOS and Android.
    By marios1441 in forum Android Apps
    Last Post: 02-28-2017, 12:39 PM
  2. Moto X Pure Edition - my "cheap" replacement for the Note 5.
    By kodos78 in forum Moto X Pure Edition
    Last Post: 02-11-2016, 01:01 PM
  3. On the Samsung Galaxy S5, how can you reset IE Default page?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 02-08-2016, 10:52 PM
  4. How do I get rid of old gmail on my Moto-E phone?
    By AC Question in forum Moto E (2014)
    Last Post: 02-08-2016, 10:16 AM
  5. Why can't I use SnapChat lens on my Samsung Galaxy S3 mini?
    By AC Question in forum Snapchat for Android
    Last Post: 02-08-2016, 10:05 AM
