1. NFOM's Avatar
    I currently use the s6 which has been my phone for around a year but the size is a problem for me it's just too small.... I'm stuck on what to do regards to upgrading..
    Either buy a refurbished note 4 for £250 or Edge plus upgrade for £390
    With the new os update will the note 4 work smoothly?
    02-13-2016 10:01 AM
  2. wm4's Avatar
    Mine is. No lag, no battery problems.
    So far!
    02-13-2016 10:18 AM
  3. Sammuel1973's Avatar
    Assuming swappable battery and/or sd card are not an issue for you since you own the S6, go for the Edge Plus. Unless you want the SPen, the Edge Plus is closer to the S6 but bigger and with better specs overall.
    silenteffectsllc likes this.
    02-13-2016 10:44 AM
  4. fragologist's Avatar
    Or you can wait for the note 6
    02-13-2016 11:16 AM
  5. silenteffectsllc's Avatar
    My note 4 is working great still. I haven't really felt any need to upgrade. I agree with Sammuel though, if the edge isn't breaking your budget since it does seem like a pretty big gap I would just get that. Or maybe check out googles new nexus phones if those work for you?
    Sammuel1973 likes this.
    02-13-2016 11:45 AM
  6. bable's Avatar
    Wait a 10 days and the edge will come down a lot after the s7 edge is announced.
    02-13-2016 09:07 PM
  7. NFOM's Avatar
    Thank for your replies I actually ended up going for Nexus 6p
    02-29-2016 12:07 PM
  1. note 5 battery life draining
    By Link169 in forum Samsung Galaxy Note 5
    Last Post: 02-16-2016, 06:26 AM
  2. Replies: 2
    Last Post: 02-15-2016, 10:06 PM
  3. Replies: 1
    Last Post: 02-13-2016, 09:39 AM
  4. Root Possible on Note 5 Verizon and AT&T yet?
    Last Post: 02-13-2016, 06:48 AM
  5. Replies: 0
    Last Post: 02-13-2016, 06:44 AM
