1. mak916's Avatar
    Anyone have any good suggestions for a bluetooth gamepad that I can use for my Samsung Gear Vr with the Note 4? It seems the Samsung gamepad is no longer available. I can't find one anywhere. What are you all using if you are not using the Samsung gamepad?
    02-14-2016 01:46 AM
  2. AXEL314's Avatar
    If the Sixaxis Controller app is compatible with your firmware, I'd suggest rocking a dualshock 3 (the app even works with those generic Chinese knock offs). This setup runs perfect on my S5 via Carl Zeiss VR one
    Android Central App | S5 G900A kitkat root
    02-15-2016 03:30 AM
  3. VR Lvr's Avatar
    I have a Note 5 and after some research I bought a SteelSeries controller for my Gear VR. After approx. 10 min, the game started spinning. I then researched further and got a PS4 duelshoock controller that a YouTube video said would work. It worked great... for approx. 15 min. Then the spinning started again. You mentioned an app that would correct the Note 4. Is there an app for the Note 5? If so, how do I use it. I'm not a big time gamer, so I would need some instruction. I'm hoping you can help me because I LOVE my Gear VR and want to play the games you need a controller for, but I'm getting frustrated. Why would they create these games when no one can play them? Then again, maybe it's just that I'm not Gamer Savvy enough. Any suggestions?
    02-15-2016 07:43 PM
  4. mak916's Avatar
    You need to be rooted to use the app that AXEL314 mentioned.
    02-16-2016 12:47 AM
  5. VR Lvr's Avatar
    Thank you, mak916.
    02-16-2016 02:11 PM
  6. AXEL314's Avatar
    Doh forgot about that!
    02-17-2016 12:47 AM
  1. Bluetooth headphone battery app
    By maverick7526 in forum Nexus 6P
    Last Post: 02-14-2016, 05:27 PM
  2. Replies: 5
    Last Post: 02-14-2016, 04:07 PM
  3. GEAR VR starts itself on my Samsung Galaxy 6S
    Last Post: 02-13-2016, 09:23 PM
