How exactly does a factory reset work? If I back up and reset will I lose all my messages? From textra, email, etc etc? My lay out, my apps, etc. I also have frostwire, I downloaded music, will I lose that music once it's been factory reset? Some, but not all, apps can be backed up to your google account. Others keep their information on your SD card. I can't say for sure about Textra and frostwire.
Do I remove micro SD card? It's not necessary, but if you would feel more comfortable knowing that the factory reset can't touch it, than by all means, pull the card out before wiping it. I personally do, just in case.
My battery life has been more than horrible since the 5.1.1 update. Battery life on 5.1.1 (I'm on T-Mobile) has been stellar. I listen to Pandora or Google Play Music literally all night at work, on LTE (9-12hrs depending on the night) and always have enough charge left to more than get me through breakfast in the morning.
I'm always on 3g as well. I'm with Verizon and I should be getting 4g LTE. But I am not. Do other Verizon users get LTE where you are? If they are, a reset MAY fix it, but a visit to your Verizon dealer may be in order
I have cleared cache, but never a reset.
Please help.
