1. wascar G's Avatar
    Am getting the same issues as well my phone jumping from 15% to shutting off ,Used to be that at 5%I wouldn't worried about the phone dying for a least 30mins .
    Go settings go to mobile data make sure that the lte/cdma is click and not the global
    Seems like That including the GPS with the phone antenna is causin a major bug with phone's battery.
    03-06-2016 11:10 PM
  2. JasW's Avatar
    My battery started doing this at about the year mark (this past October). Battery life had gotten poor, and it would just shut off when it got down to even 20%. I did a factory reset, which helped some, then at the end of January, the issue returned. I bought a 3rd party battery, which was better (and the shutdown business halted), but the battery life still does not seem quite as good as when I had a healthy OEM battery. I've since ordered an OEM direct from Samsung, but they're on backorder . . . .
    03-07-2016 12:48 PM
  3. jmagid51's Avatar
    It's a bad battery. I'm on a 3rd replacement. If you are under warranty your carrier wiill replace the battery for free.
    03-07-2016 04:07 PM
  1. Samsung Gear VR / S2 Verizon Offer Submission issues
    By cdjohnson25 in forum Samsung Galaxy S7 edge
    Last Post: 03-07-2016, 09:48 PM
  2. How long can your screen stay on in one full charge of battery?
    By Brando224 in forum Samsung Galaxy S5
    Last Post: 03-07-2016, 07:01 AM
  3. Why wont my battery charge on my droid mini and wont power 0n
    Last Post: 03-07-2016, 05:47 AM
  4. Why wont my battery charge on my droid mini and wont power 0n
    Last Post: 03-06-2016, 11:25 PM
  5. GPS and data issues
    By Sgood1692 in forum LG G4
    Last Post: 03-06-2016, 07:20 PM
