1. ahmed saad5's Avatar
    hello
    my note 4 soft ware 5.1.1. coj5 has very bad battery performance which was very very good with 4.4.4 but with locked bootloader on coj5 i can't downgrade . any way to downgrade again to kit kat
    03-20-2016 02:11 PM
  2. anon(632115)'s Avatar
    You are correct, the locked bootloader means you cant roll back. My s6 Edge battery life was poor after mm upgrade but ive been using an app called Doze for a week or so with much improved battery life. Its on Play Store
    03-20-2016 03:26 PM
  1. Podcast Player that is in sync with a PC Software
    Last Post: 03-20-2016, 02:06 PM
  2. Why do my text messages to businesses fail?
    Last Post: 03-20-2016, 02:01 PM
  3. How do I downgrade the Note 4 with Bootloader COJ5?
    By ahmed saad5 in forum Samsung Galaxy Note 4
    Last Post: 03-20-2016, 01:57 PM
  4. Need help with removing kingroot
    By AsR132 in forum General Help and How To
    Last Post: 03-20-2016, 01:51 PM
  5. How to block calls from contacts with a schedule
    Last Post: 03-20-2016, 01:42 PM
