1. AXEL314's Avatar
    Starting my second day with my fresh Note 4, and coming from my kit kat S5, reading the battery info is a little different. I've had about 40 mins screen-on-time and the battery has already drained 30% - is this normal? Also, the percentages running apps do not add up to 100 (not to mention a lack of items running to begin with). Any one have any insight?
    Attached Thumbnails Is this normal battery life?-screenshot_2016-03-31-10-40-58.jpg
    03-31-2016 12:49 PM
  2. AXEL314's Avatar
    I think I might have found the culprit (Picasa album synced). I've disabled that album in my Google accounts and hopefully I'll see some improvement - my device doesn't seem to be running hot, which is a good start.
    03-31-2016 01:27 PM
  3. nahoku's Avatar
    Yup, syncing stuff will definitely use/drain battery... especially if you're unaware something is syncing or perhaps what's being sync'd are corrupted files. Also, and I don't know if it was fixed yet, Facebook was tearing up some peoples battery time, even though it didn't show it in the battery stats percentage, so if you use Facebook and you have some strange battery issues, try disabling it to see if it makes a difference.
    I use Debloater (free) to turn off/disable some unnecessary system apps. I don't know if it runs on MM, but it does on KK and LP. You can also run Package Disabler Pro to do the same thing, and it's probably easier to use than Debloater, but then it costs $1.95 on Playstore.
    My phone never runs hot and I've had it since Jan 2015. It's still on Kitkat by choice. If your phone ever runs hot for any reason, something abnormal is going on.
    Good luck with your new phone... it has a lot of good stuff in it... not withstanding that great S-Pen! It's the last "real" Note in the series!
    AXEL314 likes this.
    03-31-2016 06:59 PM
  4. AXEL314's Avatar
    Thanks will definitely checkout Package Disabler!
    nahoku likes this.
    03-31-2016 08:17 PM
  1. S7 batter life
    By johnmcc0710 in forum Samsung Galaxy S7
    Last Post: 04-05-2016, 12:10 PM
  2. Is amazon a good place to buy replacement batteries?
    By Nicole0300 in forum Samsung Galaxy S5
    Last Post: 04-01-2016, 03:02 PM
  3. My UI system is closing
    By stefanfun5 in forum Ask a Question
    Last Post: 03-31-2016, 12:45 PM
  4. Replies: 1
    Last Post: 03-31-2016, 11:59 AM
  5. Is a Snapdragon 410 bad?
    By phoneporn in forum Ask a Question
    Last Post: 03-31-2016, 11:54 AM
