Re: Sprint Galaxy Note 4 not showing the secret menus. Help!
If you're running Nova Launcher... Add a widget, Nova activities... Then scroll down to phone info (there are 2) pick the one that says EPST when you tap it. That should put a hidden menu widget on your home screen.
