1. lovedesign97's Avatar
    Hello,
    My phone is stuck in UPSM. I can only access Messages, Google and Settings. Settings is VERY limited. I have been on the phone with Samsung. I have cleared Cache, I have gone in to safe mode, I have attempted to download from computer but the USB is not accessible except for charging.
    I have all my photos on the phone and no I didn't back up!
    I am being told that factory reset is the only way!
    I am hoping someone here might be able to help.
    Thank you in advance!
    04-16-2016 04:36 PM
  2. H3aTeRzz's Avatar
    HI
    Sorry of this is a stupid question....but, method are you using to disable it? Like my Note 5, it has a clickable "More" button on the top right while in UPS Mode,,,if you click that, and touch Turn off.....this does not work?
    Chris
    04-16-2016 05:39 PM
  3. H3aTeRzz's Avatar
    http://forums.androidcentral.com/sam...-turn-off.html
    Doesn't look like it was resolved in the above thread either.
    04-16-2016 05:43 PM
  4. cuongthai's Avatar
    I understand your feeling. I faced it twice.. The idea is to trigger the Launcher Picker again by installing/removing current launcher. So you should do adb install/remove the launcher (not the system one) and the system will ask for picking another one. Here is my note. Hope it helps
    04-22-2016 11:40 AM
  1. I can't use bitmoji on note 5/message+.
    By gawoods in forum General Help and How To
    Last Post: 04-20-2016, 11:13 PM
  2. Replies: 2
    Last Post: 04-16-2016, 06:24 PM
  3. My hisense sero 8 doesn't display correct fonts in apps
    Last Post: 04-16-2016, 03:42 PM
  4. Note 4 stuck in rebooting/struggling to turn on.
    Last Post: 04-16-2016, 02:51 PM
  5. [Jiayu S3] Bootloop and Recovery mode isn't working
    Last Post: 04-16-2016, 02:28 PM
