1. stsullivan's Avatar
    Good afternoon I'm getting ready to buy a new phone and I can't decide between the Note 4 and the Note 5 could sure use your help and your suggestions.
    Thanks for all your help and I hope you have a wonderful rest of the day.
    04-19-2016 03:49 PM
  2. AXEL314's Avatar
    I would suggest heading over to this thread to see what everyone thinks.
    http://forums.androidcentral.com/sho...d.php?t=666999
    Note 4 seems to be largely favorable for its removable battery, SD card, and IR blaster.
    Note 4 910C 5.1.1 | Android Central App
    sinfoman likes this.
    04-19-2016 04:03 PM
  3. stsullivan's Avatar
    Okay thanks so much for your help. Do you know a good place to buy a unlocked this will be my first time buying a unlocked phone I'm on prepaid AT&T again thanks for all your help.
    04-19-2016 04:06 PM
  4. natehoy's Avatar
    What's the price difference between the two for you?
    For me, even at the same price, I'd choose a Note 4. There are several features that make it worth the "older" build in my personal opinion.
    1. IR Blaster - use it a lot.
    2. Replaceable battery - I'm on my second one.
    3. SD card slot - I keep one in there to make backups of data on local memory.
    The Note 5 will get OS upgradesfor probably a year longer, of course, and has a few nice features like themes, note-taking with the screen off (available on the Note 4 with an aftermarket app), a better camera, and a few other niceties I'm likely forgetting.
    Glass versus plastic/aluminum build is a matter of aesthetics. I actually like plastic. Not everyone does.
    huntnyc likes this.
    04-19-2016 04:10 PM
  5. AXEL314's Avatar
    I personally bought mine only a month ago from B&H, the unlocked 910C model. Works perfectly on ATT
    huntnyc likes this.
    04-19-2016 04:20 PM
  6. stsullivan's Avatar
    I hear stories out there about unlocked phones about some of the band's not working do they still get updates or do they have to wait for AT&T approval
    04-19-2016 04:27 PM
  7. Kjthomas0724's Avatar
    AT&T does not push updates to their unlocked phones unless u have AT&T service.
    AXEL314 likes this.
    04-19-2016 07:44 PM
  8. zocster's Avatar
    I prefer my note 4 vs the 5. I like removable battery. And with 6.0.1, this thing is fast.
    sinfoman and huntnyc like this.
    04-20-2016 12:26 AM
  9. thetaylor310's Avatar
    i still prefer my Note 4 over 5 for all the reasons above (removable battery, SD card). i also still prefer the 4 over 5 in the aesthetic factor; to me, the 4 looks better than the 5
    over 1 year and 2 months since i bought mine, and still chugging along without any major hiccup
    huntnyc likes this.
    04-20-2016 09:12 AM
  10. thetaylor310's Avatar
    i have the 910C (Brasil/Exynos unlocked) variant and when i took it to the US during my vacation, i couldnt access 4G on AT&T
    04-20-2016 09:16 AM
  11. thetaylor310's Avatar
    can you access 4G on yours? i couldnt with mine on AT&T
    04-20-2016 09:17 AM
  12. AXEL314's Avatar
    Yes. It's the 910C UAE variant. Have you tried plugging in the network settings manually?
    04-20-2016 09:24 AM
  13. thetaylor310's Avatar
    hey axel,
    how do you do that?
    04-20-2016 12:46 PM
  14. AXEL314's Avatar
    hey axel,
    how do you do that?
    This is the page I referenced. Hope it helps.
    https://apn.gishan.net/settings/833_...axy_note_4.php
    thetaylor310 likes this.
    04-20-2016 12:53 PM
  15. thetaylor310's Avatar
    if i had known this earlier...
    thanks so much for the tip. the next time i go visit the States, ill give it a go
    04-20-2016 02:22 PM
  16. sinfoman's Avatar
    swappa.com. You're welcome.
    04-20-2016 03:22 PM
  1. To buy a Note 5 or buy Note 4 please help
    By stsullivan in forum Samsung Galaxy Note 5
    Last Post: 04-22-2016, 12:51 PM
  2. Replies: 2
    Last Post: 04-19-2016, 07:44 PM
  3. Replies: 1
    Last Post: 04-19-2016, 03:35 PM
  4. Replies: 1
    Last Post: 04-19-2016, 03:30 PM
  5. Replies: 0
    Last Post: 04-19-2016, 02:35 PM
