1. treske23's Avatar
    I have had my current note 4 for a couple months and it randomly shuts down and freezes. I had a previous note 4 that did this same thing right before it completely died on me. Does anyone know what might be causing this. It is currently running Android 6.0.1 but it had this issue in multiple stages of lollipop as well
    05-03-2016 09:21 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If you have the exact same apps installed as on your previous Note 4, then I would be suspicious of one of the apps. If it never freezes or shuts down randomly in Safe Mode, then you know it's some app you installed. Unfortunately, the tedious challenge afterwards is to uninstall apps one by one until the problem goes away. I see that you've already started doing that from reading your other post: http://forums.androidcentral.com/and...ml#post5158974
    05-03-2016 11:02 PM
  1. Syncing contacts from Note 5 to Gear S2
    By kdburton in forum Samsung Gear S2
    Last Post: 05-05-2016, 11:20 AM
  2. Note 4 won't allow factory reset.
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-04-2016, 06:58 PM
  3. Replies: 0
    Last Post: 05-03-2016, 07:01 PM
  4. Is there an app for taking spherical photos for Note 5?
    Last Post: 05-03-2016, 06:54 PM
  5. Text problems on my Note 5
    Last Post: 05-03-2016, 06:34 PM
