1. Dede2910's Avatar
    Is there anyway to zoom the front camera on Note 4?
    When taking selfies i like to zoom in the front camera ..this feature was avaliable in my Note 3 with applications "Youcam perfect" and " camera 360 ".
    I tried selfie stick with zoom buttons but still not working..
    Please help..
    Also if you know any moble phone has this feature please let me know..
    05-11-2016 10:17 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved from the Samsung Cameras forum to the Note 4 forum.
    Have you tried those same camera apps on your Note 4, or are you only using the stock camera app?
    05-11-2016 09:13 PM
  3. Dede2910's Avatar
    Hi B. Diddy..
    yes i ve tried the same app on my Note 4 but not working.
    I ve set the volume button on Camera360 to zoom instead of capture but the zoom will work for rear camera only.. i was not able to zoom the front cam for selfies with and without the selfie stick.
    05-11-2016 11:18 PM
  4. nahoku's Avatar
    Google Camera will zoom selfies, although I have no idea if it'll work with a stick. You won't find Google Camera on Playstore anymore so you'll need to get it from APKPure. Download version 2.5.052 and sideload it. If you don't know how to sideload, post back for some help.
    By the way, I use APKPure a lot and have had no problems with apps downloaded from there.
    05-12-2016 02:33 AM
  5. Dede2910's Avatar
    I ve already tried this app..still not working.
    05-12-2016 09:00 AM
  6. Kjthomas0724's Avatar
    The app camera360 allows you to zoom in when taking a selfie
    05-12-2016 10:02 AM
  7. Dede2910's Avatar
    Yes this is what i was thinking too..but when i set the volume key for zooming it adjust the volume instead of zooming.
    05-12-2016 04:02 PM
  8. Dede2910's Avatar
    Please, can any one with Note 4 try if the zoom works for fornt camera using app camera 360?
    05-14-2016 10:16 AM
  9. Kjthomas0724's Avatar
    Yes, zoom works on front camera on 360
    05-21-2016 12:22 PM
  10. Dede2910's Avatar
    Hi Kjthomas0724
    do u use note 4 ?
    I really cant understand why it is adjusting the volume when i chose zoom function.. is it a phone problem?
    05-26-2016 12:30 PM
  11. Kjthomas0724's Avatar
    Yes I have a note 4. I don't take a ton of selfie but when I do I don't have a problem with the zoom
    05-27-2016 01:32 PM
  1. Replies: 3
    Last Post: 05-15-2016, 06:55 PM
  2. Replies: 1
    Last Post: 05-11-2016, 04:54 PM
  3. Replies: 1
    Last Post: 05-11-2016, 04:48 PM
  4. Turn off LED in Do Not Disturb mode
    By Mugenized in forum HTC 10
    Last Post: 05-11-2016, 07:14 AM
  5. Samsung Galaxy s7 alarm in the clock app doesn't go off!!!
    Last Post: 05-11-2016, 06:48 AM
