1. cutesnuggles's Avatar
    Hi. My phone did the Marshmallow update yesterday and ever since then the system notification & low battery noises are so low I can barley hear them.
    The volume is right up and it is no where near as loud as it used to be.
    Please help!!
    05-20-2016 08:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are other media sounds normal volume? Have you tried wiping the cache partition? https://support.t-mobile.com/docs/DOC-14686
    05-20-2016 04:47 PM
  3. Catallin's Avatar
    also having the same problem.
    tried everything i could find online, wipe cache partition, even hard reset - nothing.
    any solutions or suggestions?
    05-28-2016 05:54 PM
  4. Catallin's Avatar
    anyone?
    05-30-2016 04:22 PM
  5. Catallin's Avatar
    I've flashed 3 different stock roms, nothing changes.
    Ideas?
    05-31-2016 06:07 PM
  6. Catallin's Avatar
    - flashed 5 roms (different regions) - same result / settings
    - root + custom recovery + file exporer to try and change the gain config. - failed, even with the new config.
    The problems are: very low lock/unlock sounds and dial tones.
    come on guys, suggestions?
    06-08-2016 05:49 PM
  7. AXEL314's Avatar
    Are all the slides adjusted accordingly? Maybe your phone took on some water (though water resistant, my S5's speaker volume was affected after exposed to water)?
    Note 4 910C 6.0.1 | Good Lock UI | Android Central App
    Attached Thumbnails Low volume after Marshmallow update.-screenshot_20160608-164017.jpg
    06-08-2016 06:42 PM
  8. gvlakers's Avatar
    Same problem here after MM update....I say its a bug. And for as much time as they had to push this to the Note 4...what a joke
    06-08-2016 07:15 PM
  9. Catallin's Avatar
    - every setting has max. volume (including system)
    - the speaker is blasting very well on music, notifications, ringtone or loudspeaker.
    * the only thing that drives me nuts is the low volume on lock/unlock sounds (tried every lock screen bubble, water etc.) and dial pad sounds.
    06-09-2016 06:56 PM
  10. Catallin's Avatar
    a bought a second note 4 and the same issue.
    can someone post a video with the unlock sound (max volume on "system" volume slider)?
    06-22-2016 05:01 PM
  11. Ronald E Bartholomew's Avatar
    I'm having the same problem even after wiping the cache
    07-18-2016 09:35 AM
  1. In call volume to loud on galaxy s7 edge
    By Flooo20 in forum General Help and How To
    Last Post: 05-21-2016, 03:18 AM
  2. 2016 update - bleeping & water ripple
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-20-2016, 06:32 PM
  3. Replies: 2
    Last Post: 05-20-2016, 10:44 AM
  4. Marshmallow pop up not working
    By CarlosSW in forum Samsung Galaxy S6
    Last Post: 05-20-2016, 07:29 AM
  5. new update... always error occur...
    Last Post: 05-20-2016, 07:27 AM
