While I understand the sentiment I can't say that I agree with it completely - if the majority of batteries are living past the manufacturer's warranty period before exhibiting the behavior then they're working as designed - we may not like it but the bottom line for manufacturers is to design products that last long enough to work for the intended product life, not to last for years and years.
As the market has progressed to thinner and thinner devices the battery technology has had to adapt too, it's probably not appropriate to compare historic battery performance to that of newer devices with thinner or newer battery tech. Surely yield and lifespan is impacted when battery designs are pushed to the limit in terms of thinness.
I'm one of those whom NexusGirlX notes would swear to never go too low between charges and I can honestly say that my charging habits of keeping percentages north of 40% has NOT kept me from seeing a failed battery on my Note 4. I've had one swell and fail so yeah at the end of the day I just use the device however I need to use it and I'll replace the battery when it needs to be replaced. My Note 4 isn't the only battery I've ever had fail either - I've had one swell in a Nexus 4 (was over 2 years old by then) and an iPhone 5.
It is what it is . . I'm thankful that the battery on this phone is easily replaceable and affordable. . at the same time though, production of batteries for it will sunset (if it hasn't already) and eventually nothing but old stock will be left with limited lifespans. My Nexus 4 is still going strong with the battery that I had to put into it (which wasn't as easy as the Note 4) but the market for batteries for it is limited.
Here's hoping that battery tech continues to improve in future devices.
