1. astroprojector's Avatar
    Hello,
    I will be traveling to Canada and was wondering if I can use my Verizon Note 4 (SM-N910V) with a sim card from any of the Canadian carriers. I am not sure if my phone region unlocked.
    If some one can answer these questions, it will greatly appreciated:
    1. How can I found if my phone region unlocked?
    2. If it is not region unlocked, how do I unlock it?
    3. If it is unlocked how do I get it to work on Canadian carrier?
    Thank you
    06-15-2016 09:08 AM
  2. srkmagnus's Avatar
    Hello,
    Thank you
    Verizon offers International support, including Canada: International Travel | Verizon Wireless
    I would suggest contacting Verizon to see if there is a plan that works for you. Otherwise, you'll need to unlock the device in order to use another carrier's SIM card while in Canada.
    06-15-2016 09:35 AM
  3. astroprojector's Avatar
    Thanks,
    The Verizon plan is much more expensive than using SIM card from CA carriers. Do I need to call Verizon and ask for the unlock code?
    06-15-2016 09:39 AM
  4. cganesh's Avatar
    Verizon Note 4s are factory unlocked so you can use a foreign sim card as long as you are not in U.S. GSM foreign sim may require you to manually set APNS so if first time get sim card at a store who has someone who can help with APN set up. Not difficult once you know how to do it. Usually the APN settings come with the sim card.
    07-09-2016 09:31 AM
  1. Can I flash the T-Mobile rom on my Verizon galaxy S5?
    By brcjacks in forum Samsung Galaxy S5
    Last Post: 08-21-2016, 03:15 PM
  2. Replies: 3
    Last Post: 06-18-2016, 01:38 AM
  3. Note 5 Contacts Car Sync problem after Marsmellow
    By jatavares in forum Samsung Galaxy Note 5
    Last Post: 06-16-2016, 11:35 AM
  4. Shooting in RAW = Unknown error by ErrorCallback
    By Sorensiim in forum Samsung Galaxy S7 edge
    Last Post: 06-15-2016, 06:55 AM
  5. Incoming SMS message is not coming in my samsung mobile
    Last Post: 06-15-2016, 05:45 AM
