1. droidntn's Avatar
    When I have my phone in 'power saving' mode after the MM update, it DOES really conserve the power, but at the cost of phone usage.
    For example, I can't send an MMS. I attach a pic in messaging and it never sends, just sits there.
    Or if I have Spofity streaming, it'll stop after one song. Have to restart the app.
    Or if forming a new text message, it lags really badly behind the words you are typing. And then just catches up all at once.
    Or Facebook will say 'can't connect right now'.
    Any of you guys having these problems?
    Is there some new setting I've not done right after reformating to factory and installing Marshmallow?
    06-17-2016 06:26 AM
  2. Paradroid01's Avatar
    Welcome to another feature of Marshmallow! ๐Ÿ˜ƒ
    06-17-2016 04:54 PM
  3. droidntn's Avatar
    So this is normal?
    Posted via Note 4
    06-17-2016 06:31 PM
  4. emad1995's Avatar
    The power saving mode basically shuts off background data for your apps. You can turn this off for certain apps like Spotify so when you are using power saving mode it is left unaffected. Not sure where the setting is on the note 4 but on my s6 it's in settings>battery>more>battery optimization.
    Hope this helps ๐Ÿ˜Š
    06-17-2016 09:13 PM
  5. kirksucks's Avatar
    Ultra Super Power saving mode = turn off phone.
    06-18-2016 09:05 AM
  6. droidntn's Avatar
    Hope this helps
    That helped a LOT. Thanks!
    06-20-2016 05:46 AM
  1. Vibration during "do not disturb" Android Marshmallow
    By AC Question in forum Samsung Galaxy S7
    Last Post: 06-17-2016, 12:59 PM
  2. Why did the margins on my Moto G3 start screen get smaller?
    Last Post: 06-17-2016, 08:15 AM
  3. How do you exit safe mode on a Samsung galaxy S6?
    Last Post: 06-17-2016, 06:25 AM
  4. 0 and p buttons not registering after marshmallow update
    By MCHKK3Z in forum Samsung Galaxy Tab S2
    Last Post: 06-17-2016, 01:36 AM
  5. Replies: 0
    Last Post: 06-17-2016, 12:42 AM
