1. AC Question's Avatar
    My galaxy note 4 fast charging doesn't work in my car plug. The plug used to charge fast but when I bought a new cable because the other one broke it doesn't charge fast anymore. It just holds the batery. Maybe. My phone charges fast when connected to the wall. I've change the cable 3 times now and I can't get it to work.
    What specs do I need for the cable to work and fast charge my phone??
    06-24-2016 10:14 AM
  2. Clocks's Avatar
    Certain cables won't work. I would browse amazon micro usb cable reviews until you find one that someone says works with quick charging on the note 4.
    06-24-2016 06:11 PM
  3. dabombcra's Avatar
    The quick charger you plug into the wall is what gives the battery a quick charge. The car chargers are not set up to quick charge
    AXEL314 likes this.
    06-25-2016 02:52 AM
  4. ratsttam's Avatar
    There are numerous chargers that support CQ2. I have one in my truck and one in my girls car. Both show up on the phone as "fast charging" correctly.
    Besides, the OP said it WAS working until they changed the cable out due to damage.
    06-25-2016 04:50 AM
  1. My messages are not coming through my ZTE 5.0 phone. How can I repair this?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 06-26-2016, 03:20 AM
  2. Why is my dialer is not working
    Last Post: 06-24-2016, 11:24 AM
  3. Replies: 1
    Last Post: 06-24-2016, 10:13 AM
  4. I want to connect my LG G3s to my wlan
    Last Post: 06-24-2016, 10:04 AM
  5. How do I disable the Verizon drive mode on my Galaxy S5?
    By Kalel56 in forum Samsung Galaxy S5
    Last Post: 06-24-2016, 08:35 AM
