1. androidchat's Avatar
    This morning, after the latest software update (Marshmallow), my phone required me to enter a pattern to log back into my phone. I didn't have to enter a pattern code before! Now, after several unsuccessful tries, its asking for a back-up PIN--which I also don't know! I need help on how to log back in!!
    Earlier, I asked this same question on this forum and I was told: "Use Android device manager to lock the phone with your google account"
    But I'm not sure how this suggestion helps at all. I need to "unlock" my phone, not "lock" it. I logged into Google, but my phone has to have been registered previously for ADM to work at all. Any other advice on how I can get back into my phone without doing a factory reset??
    06-28-2016 05:53 PM
  2. dpham00's Avatar
    Mod Note , I will move this to the note 4 forum for more visibility
    06-28-2016 06:31 PM
  3. nahoku's Avatar
    If you can't figure out the pattern, and you never had a pin, and you can't use ADM, then factory reset is your only choice.
    06-28-2016 10:20 PM
  1. Replies: 2
    Last Post: 07-03-2016, 09:37 AM
  2. Interesting devices, Wileyfox...
    By Golfdriver97 in forum Wileyfox Spark Series
    Last Post: 06-29-2016, 10:59 AM
  3. Can't log in
    Last Post: 06-28-2016, 06:34 PM
  4. How do i disengage sleep mode on my turbo2
    By AC Question in forum Motorola Droid Turbo 2
  5. Replies: 1
    Last Post: 06-28-2016, 06:33 PM
