1. Jessica V's Avatar
    I've had my note 4 for 2 years now and only about 3 months ago a blue screen pops up when I connect it to the charger that gives me my battery percentage, date/time, and also says "Speed...Continue.....Trickle" with a progress bar kind of thing under it. I don't download sketchy apps or anything like that so I don't think that could've caused it. But no one else I know with a note 4 has had this. And it just popped up out of nowhere one day. Has anyone else had this happen to them or know what it is? Is there any way I can access this feature's settings within my phone?
    06-28-2016 10:09 PM
  2. SpookDroid's Avatar
    Actually, you did download a 'sketchy' app. Which one, however, I'm not sure, and not always are they that sketchy. I think popular apps like ES File Explorer starting including this in their apps. Unfortunately Google allowed ads on charging screens now, and some apps are taking advantage of this. You SHOULD see a settings button in that screen, however, that should let you turn off that 'feature'.
    06-29-2016 02:36 AM
  3. MrMELTDOWN's Avatar
    I had the same screen appear on my Note 4 one day all of a sudden. The culprit was DU Battery. I installed and ran "badapp".....finder or something. It gave me a few possibilities. I unintalled a few apps until I found the app, DU Battery, that was causing the problem.
    06-29-2016 01:20 PM
  1. Htc one m8 usb connection dont show all files
    Last Post: 07-05-2016, 08:54 AM
  2. My Galaxy Tab Lock screen Won't stay in Landscape.
    Last Post: 07-05-2016, 08:53 AM
  3. How to put the hour on the wall paper
    Last Post: 06-29-2016, 07:40 AM
  4. Why is my kindle fire charging so slow?
    Last Post: 06-29-2016, 07:37 AM
  5. Can I take a sprint galaxy s6 to straight talk?
    Last Post: 06-29-2016, 05:53 AM
