1. isabel95's Avatar
    This is since the Marshmallow update.
    I am really puzzled. Used to be the biggest user of battery was the display. I just can't figure why wi-fi is using so much. I thought I read that turning it off (except when I'm in the car, when I turn both it and data off unless I need the data, which I turn on.)
    07-10-2016 08:31 AM
  2. Golfdriver97's Avatar
    Is there anyway you can show us a screenshot?
    07-10-2016 10:05 AM
  3. isabel95's Avatar
    Sadly, not. I just recharged the battery. I can add that display usage was only 1%! I can post battery usage statistics the next time I have to recharge.
    Golfdriver97 likes this.
    07-10-2016 10:12 AM
  4. isabel95's Avatar
    Attached is a screenshot I just took of my battery usage, with the message that I still had 6 hours of usage left, right after I got a beep telling me to plug in my phone to recharge.
    I've changed a setting so that wi-fi is not on when the phone is sleeping. I also turn wi-fi off when I am out of the house. I don't know what other changes I can make to reduce the use of wi-fi, which never was a problem before Marshmallow.Battery Usage:  73% Wi-fi?-screenshot_2016-07-11-17-55-15.jpg
    07-11-2016 06:06 PM
  5. Golfdriver97's Avatar
    Have you done a cache clear in recovery?
    07-11-2016 08:45 PM
  6. RadeonHD4250's Avatar
    I'm having weird WiFi usage. Mine doesn't necessarily show up in battery stats; however it does keep my device awake longer than it should.
    07-11-2016 09:32 PM
  7. isabel95's Avatar
    Yes...following these directions from Verizon, but choosing the one to empty the cache, NOT the system reset. Factory Data Reset (Powered Off) - Samsung Galaxy Note 4 | Verizon Wireless It's looking more and more that my only alternative is a dreaded system reset.
    I just unplugged the battery and turned on wi-fi and will monitor battery drain before I do anything rash.
    07-12-2016 07:01 AM
  8. Golfdriver97's Avatar
    I'm at a loss for anything else to suggest. Back everything up, make sure contacts are in Google or other cloud service.
    If you use Nova, that can help with restoring your homscreen setup.
    07-12-2016 01:27 PM
  9. isabel95's Avatar
    I have a Samsung Tab S2 which is set up similarly - perhaps I can Smart synch from that?
    07-12-2016 02:34 PM
  10. isabel95's Avatar
    I am not the only one!
    Have been researching this issue and found MANY people are experiencing the wi-fi battery drain - even with wi-fi turned off.
    https://productforums.google.com/for...us/NB0izQHuBaU
    Aside from the wifi issue I read that Marshmallow changes networks to Global and that we ought to turn back to LTE CDMA.
    07-13-2016 07:46 AM
  11. isabel95's Avatar
    Just returned from reporting the Wifi situation to Verizon and they said Samsung is aware of the problem - so perhaps they will HOPEFULLY issue a fix.
    Meanwhile, my husband's Samsung S6 phone, also with Marshmallow (6.0.1) doesn't have the wi-fi drainage problem - so it's probably something about the interaction of Marshmallow and SOME phones. A friend with the Note 4 has reported shorter battery life, as well, but didn't mention what her wi-fi usage is.
    07-13-2016 12:57 PM
  12. isabel95's Avatar
    yes....two times...after letting the battery nearly empty - down to 3% power - I recharged and the problem has gone away!
    I was getting really upset when two friends with Marshmallow updates on their phones didn't have the wi-fi usage problem.
    (Reply was posted in wrong place - someone asked if I had done a recovery mode cache empty - and this was a response to him - sorry).
    Attached Thumbnails Battery Usage:  73% Wi-fi?-post-fix.jpg
    07-14-2016 11:02 AM
  1. "Android System" battery drain
    By rashadj1 in forum Samsung Galaxy S7 edge Rooting, ROMs, & Hacks
    Last Post: 02-25-2017, 01:03 PM
  2. Horrible battery life. Please help!
    By Artjunkie1 in forum LG V10
    Last Post: 07-21-2016, 04:51 PM
  3. Pokemon go,,,, god bless removable spare batteries
    By Ryaan Johnson in forum LG V10
    Last Post: 07-19-2016, 04:21 AM
  4. Get 7h to 8h battery life on extreme use and 9 to 10 hour normal use
    By Insurgent-Naqi in forum Samsung Galaxy Note 5
    Last Post: 07-17-2016, 03:16 AM
  5. Replies: 0
    Last Post: 07-10-2016, 02:45 AM
