1. Qazi Inam's Avatar
    My note 4 ir led stopped working a month ago i viewed it using *#0*# but it does not blink... i viewed it in a camera..my front camera and proximity/light sensors are working fine...is there a hardware or software problem???
    Or is there any solution to problem? Please help
    07-11-2016 06:00 AM
  2. mstrblueskys's Avatar
    Based on the info you provided, it's almost certainly a hardware issue. Sorry.
    dabombcra likes this.
    07-11-2016 01:49 PM
  3. dabombcra's Avatar
    I agree, it has to be a hardware issue. Mine is working just fine
    07-11-2016 08:58 PM
  4. Qazi Inam's Avatar
    If i had to get a replacement of ir led will my camera and sensors also be changed?
    07-12-2016 12:51 PM
  5. Qazi Inam's Avatar
    If i get it replaced from samsung franchise how much will it cost?
    07-12-2016 12:52 PM
  6. dabombcra's Avatar
    You will have to call them. Look locally at a phone repair shop. Maybe it just has a bad connection that has to be fixed.
    07-13-2016 07:51 PM
  7. Qazi Inam's Avatar
    I went to samsung franchise but they say that we cannot change bcz it is out of warranty..i went to a local shop but they say we haven't encountered such complaint from any customer so we haven't tried it..nobody has done it before
    07-25-2016 06:37 AM
  8. Qazi Inam's Avatar
    Proximity sensors,front camera and IR are on same chip..if its a chip malfunction then the other two shouldnt work...and is there any possible way that only the IR emitter has to be changed??
    And has this repaired before only the emitter.?????
    07-25-2016 06:40 AM
  9. Qazi Inam's Avatar
    This is how front camera chip is showing IR and front camera..
    Can the highlighted area be replaced only..I mean is it possible??
    Or whole chip will be changed...expert opinion required here...
    Plzzzzzzzz
    07-25-2016 06:49 AM
  10. dabombcra's Avatar
    Maybe it is a software issue. A factory reset should fix it if it is software related
    07-29-2016 07:56 PM
  11. Qazi Inam's Avatar
    It was h hardware issue i got it replaced now working fine
    natehoy likes this.
    08-03-2016 09:34 AM
  1. My note 4 ir led is not working
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 10-19-2016, 04:04 PM
  2. Tab s2 keyboard not working after Marshmallow update
    Last Post: 08-29-2016, 07:13 AM
  3. Replies: 2
    Last Post: 07-11-2016, 06:33 AM
  4. Replies: 0
    Last Post: 07-11-2016, 03:38 AM
